markwj, I agree with you. This already IS good enough for it's purpose. No need to enhance it even more. I sure still hope Tesla will implement this in a new firmware. It should be time for a new one with other enhancements as well.
Mark that's impressive. I'd like to work on a small 7-segment display I can put up there. Your eyes must be a lot better than mine because I can't read my amps when driving unless I bend down and squint... I have too many irons in the fire to do it now but if nobody has done it by May, then I will. Thanks for all the great contributions you have made!
Hey, Mark, can you maintain a reasonable update rate without flooding the bus, but simply listen for the AMPS update and then use that event to immediately follow up with a MPH message? Thus, the only time that there's a rush to send out a MPH message is right after an AMPS message has been received.I should say that it is still possible, and probable, that a real AMPS message could sneak in and be momentarily displayed. We can't stop the car sending these AMPS messages (without hacking the Tesla firmware) - all we can do is quickly follow them up with our own version of the message (showing the speed instead of AMPS). The approach seems to work 99.99% of the time, but I guess we're still going to see a momentary jump every minute or two. If you look at the previous video, I was getting a jump once every five or ten seconds. I've now got it down to once every few minutes. We can get more aggressive to make it even better (flood the bus with spoofed messages), but that is probably not a good idea ;-) It will never be perfect. But, perhaps, good enough.
I'm hoping after the Model S launch, there will still be an engineer or two assigned to the Roadster. They may get bored and work on projects like this.Bottom line, is it would be best for Tesla to do this. I've shown it can be done, and works well. For them, it is a trivial code change, but all the safety, QC and other stuff that must be gone through to make any change makes it work with a lot of downside if they get something wrong. Tesla's emphasis is on the Model S (as it should be), and I'm not holding my breath waiting for this...
There is an app for that also. Try the Escort Radar application for the I phone. It has a "Dashboard" option that gives a pretty accurate speed via the GPS in the I phone. Just mount the phone where it is visible to you. Search apps for "Escort Live"
The problem with the Alpine is you have to stay on one screen. If you want to see the Nav or the music, you have to navigate away from your speed. It does work though.The Alpine units offer the same.
But, not in tunnels or areas with tall buildings (which describes where I live).
Does the car stereo have an option to automatically adjust the volume with the speed? If so, you may be able to pick up the signal behind the head unit, if that's easier to get to. Also, since the radio is a 3rd party commercial product, you should be able to find a full installation manual which will help to track down the correct wire.Alternatively, can the speedo pulse stream be picked up earlier, or somewhere easier to access ??
Hi. On the 2.0 its a varying frequency square wave. The red trace is about 50mph
Hi - the trace is from the tach / speed feed to the single DIN alpine head unit.
The waveform is from a PicoScope automotive oscilloscope (my company makes them).
Has anyone implemented this using a separate display like a 7-segment or something different than the LCD below the speedo? I have trouble reading the LCD and would like a better, more visible solution.
Why not use the display of your smart phone, where it already has a nice housing and existing in-car mounting solutions.Thinking about this as a long-term evolution of OVMS. Put a 2.5" touch screen LCD on it and have it on the dashboard. As we're on the can bus, there is a wealth of information that could be displayed. The modem would allow remote control. The displays are not that expensive, but a nice housing is tricky.
