How does putting the new tires on the front help them to wear evenly?
front tires generally wear more quickly because they are used laterally (to steer) and not just rotationally (to go around and around). And esp FWD or AWD they are drive wheels as well.
Since most cars now have stability control and general suspension design that heavily favors understeer, oversteer is much much less common than understeer.
However, there are three types of people:
When the car starts to oversteer they:
A: have no idea what to do and watch as the car's rear trades places with the car's front.
B: vaguely recall from driver's ed that you are supposed to steer into a spin out and they wrench the steering wheel hard over and hold it until eventually the car over corrects and oversteers in the other direction and they spin out the other way.
C: they sense the oversteer and they slide the wheel over briefly to give it enough to come around and quickly nudge the wheel back -- or they let stability control effect roughly the same thing with the inside front brake.
Types A and B can put the new tires on the back to help them avoid their catastrophic spinouts, but now they are at a much higher risk for the much more common understeering off the exit ramp curve.
every car I had since 2001 has had stability control and it was near impossible to get them to spinout even fooling around in snowy parking lot. Seems a waste to put the slippery tires on the front to encourage the much more common understeer in exchange for protection against the rare rare oversteer. (and since stability control works mostly with the front brakes you are not giving ESC the right tools to work if you are putting the crappy tires in the front.
