Yggdrasill
Anyone notice the powerpack specs?
One significant detail is the "210 kWh (AC)" wording. That means that this is the storage capacity for round-trip AC power, and that the actual DC battery capacity is closer to 220 kWh.
This also fits better with the Powerwall capacity, if we assume the Powerwall uses one pod, and the Powerpack uses 16 pods, the expected capacity for the Powerpack based on the Powerwall capacity would be 14 x 16 = 224 kWh.
Looking at the dimensions, a Powerwall is 1150mm x 755mm x 155mm, while a powerpack is 1014mm x 1254mm x 2192mm. The likely size of each pod would be around 700mm x 700mm x 110 mm. This means a volumetric energy density of around 260 Wh/l on the pod-level, where the old Powerwall had a volumetric energy density around 180 Wh/l on the module level. That's around a 50% improvement. (I'm assuming the new pod only contains one new larger-format module.)
I estimate at most around approximately 35% improvement as a result of a new pack layout and 21-70-cells. Which means that the chemistry must have been improved by *at least* 10%. More probably up to 20%.
That's pretty good. Improvements due to chemistry are basically money in the bank, as the cost per cell is pretty much constant.
EDIT: Actually, looking at the picture below, I think my pod dimensions are a bit off - I think the inverter is included in the pod itself, with only the temperature management outside the pod. The larger format battery module is likely around 700mm x 700mm x 110 mm, while the entire pod is likely around 900mm x 700mm x 110mm. It doesn't affect my calculations though, it just means I'm comparing module with module rather than module with pod.
