deonb
What probability do you think these two cases will happens? Also by what time frame? You indicated option play so the time consideration is a key factor.
Here are my thoughts for fun. Do NOT take this for investment advise - I'm just showing my thought train - plug in your own numbers and odds.
Assuming $140 on Wednesday:
a) 25% odds: Strong positive (5400, 25000 guidance, second line opening, 15c profit) - 15% gap up - opening $161.
b) 40% odds: Positive (5200, 22500 guidance, 3c profit) - 8% gap up - opening $151.
c) 20% odds: Meet / weak positive (5000, 21000 guidance, 5c loss) - 15% gap down - opening $119.
d) 14% odds: Negative (4800, lowering guidance, > 5c loss) - 33% gap down - opening $93.
e) 1% odds: Some magical set of numbers that causes TSLA to stay within $5 before and after ER. In related news, Nasa discovers Jimmy Hoffa still alive on Mars.
That's opening bell. After that over the next 2 weeks, I think:
(a) will trend further up (mild short squeeze, positive press + forced upward adjustments from analysts) to around $170. Could also trigger a violent short squeeze, in which case up to $255 (50% up) and back down to $110 over a matter of hours. After obvious short squeeze, enter a $110 to $130 range. If it doesn't go through an obvious short squeeze, enter a $150 to $170 range.
(b) will fill half the gap that day and then enter a $140 to $160 range.
(c) will drop further to about $100, find support and recover to enter a $100 to $120 range.
(d) will further drop down until it hits $70, then recover to enter a $80 to $100 range.
(e) Hoffa announces run for President.
