Has anybody actually had the recall performed? They did something to reduce the wind noise on mine P85D about a month ago but the wind noise is back and seems worse.
Patrick
The invoice didn't say anything about the recall, it just said "noise. Installed foam to reduce the amount of wind incomming to cabin."
My car is going back next week to have my new seats installed so hopefully they will apply the TSB then.
Do you know if the TSB is specific to the P85D or does it apply to other models?
I have a 85 with a vin of 732xx and at 65 MPH+ I have wind noise up front, was thinking about taking some wide blue painting tape and trying to narrow down if it's the window, small triangle window, or sunroof.
I don't know the specifics of the TSB. I just know that I had reported the issue to my service center, and some time later they told me there was now a TSB for it, but they were waiting for the parts to be able to perform the TSB.
Any updates on having the TSB performed and results?
My P85D has just started doing this pretty badly in the triangle window area. I'm surprised because I thought they'd licked this.
Can some black silicone along the bottom of the window fix it too, would you think? (where your snow is coming in)
-m
I had the wind noise issue fixed today during my annual service and this is what they did:
"Performed several test drives on high way to investigate wind nois a-pillar. Adjusted front part of door seal at body side. Applied foam behind bright work. Applied foam tape behind sealing. Retested and found in order."
The wind noise is gone so I'm a happy camper.
