For the MC240, if you removed the GFCI, and if you changed the circuit to ask for 40amps then it might work, but then you have to wonder if the wire gauge is up to the task.
Remove the GFI and replace it with a 50A contactor. The cable is #6AWG so it's good for up to 55A.
By the way, the Roadster foundry kit has thermal sensors in the plugs to reduce load if the plug/socket starts to overheat. I don't know if the MC240 does that.
There are no temperature sensors in MC240 NEMA plug or tesla connector. However there is a connection on PCB (labelled "sense") inside the MC240 that could be used to measure temp, but nothing is connected to it.
It would be nice to have pictures from inside the foundry charger... But can anyone tell me if the can hear a click from inside the foundry charger? The MC240 has a click from the GFI when you slide the tesla connector.
-Scott
