Yup. It is working now. Seems to have issue if there slow or connectivity issue to the tesla..it exit I thinkTry restarting your Apple Watch?
Glad you got it work again.Yup. It is working now. Seems to have issue if there slow or connectivity issue to the tesla..it exit I think
You got it. I'll give it the highest rating.Version 3.3.3 is out now, and that should be the last bug fix/minor update in the 3.3.x release. One thing I haven't mentioned in my release notes is that there is a complication for Remote S, but it is simply a shortcut to the app right now. There's no icon, stats, or graphic associated with the complication at the moment. Just tapping on the blank area where you placed the complication will bring you straight to the Remote S app.
The reason why I haven't mentioned it is because I plan on adding information to the complication in the next major release version 3.4.x. It's going to be a while before the next update while I work on it and other features. So if there's any other feature you want me to add or any other bugs you find, let me know. I'll add it to my list of things to do for the next major release.
Also, since my app's ratings/reviews get wiped out after every update, I appreciate those who leave a rating or review. It helps a lot with sales when people see that the app is used by many.
Ah, it's because you have "More Precise Stats" turned on, so you never got a chance to see the full labels for each stat. But the rate on the very top is for instantaneous readings. 15.62 mph is how fast your battery is gaining miles at that moment. The top left number is how much power your battery is gaining. The ones on the bottom are your charger's stats. They're the same stats you see on your dashboard or official Tesla app when charging. The 18.70 is the average rate (in mph in your case) of charge. The one above is the power your charger is giving out. You'll notice that the numbers don't match the instantaneous battery stats. This is probably because you have your HVAC on, and HVAC usually drains about 3 mph or 1 kW - but it really depends on how much your HVAC has to work.View attachment 198230
Can somebody explain the difference between the two numbers indicating current power and the charge rate in MPH? I'm assuming one of them is average and the other is instantaneous?
Awesome! Thanks for the explanation. So just to clarify, the bottom numbers always match what's displayed on the dash? Hence they're "average" numbers?Ah, it's because you have "More Precise Stats" turned on, so you never got a chance to see the full labels for each stat. But the rate on the very top is for instantaneous readings. 15.62 mph is how fast your battery is gaining miles at that moment. The top left number is how much power your battery is gaining. The ones on the bottom are your charger's stats. They're the same stats you see on your dashboard or official Tesla app when charging. The 18.70 is the average rate (in mph in your case) of charge. The one above is the power your charger is giving out. You'll notice that the numbers don't match the instantaneous battery stats. This is probably because you have your HVAC on, and HVAC usually drains about 3 mph or 1 kW - but it really depends on how much your HVAC has to work.
You really begin to notice the difference when you're supercharging. This is when sometimes the average towards the end would say something like 60 mph. But in reality, it's only charging 3 mph at that moment. This might give you better information to decide whether you really want to wait that extra 20 minutes to gain that extra mile range when you're at 99% already.
Correct. Well. Not always. The bottom numbers only match the dash when it's charging. Hence the "Charge Info" label on top. When it's not charging, it shows "Battery Info", which is your instantaneous battery info again. When you're charging, that battery info gets shifted to the top bar to make room for the "Charge Info".Awesome! Thanks for the explanation. So just to clarify, the bottom numbers always match what's displayed on the dash? Hence they're "average" numbers?
Is the car icon to the left of Remote S a solid white or an outline of a car? Solid white = app is actively connected to the Tesla server for summon/homelink. Outline of the car = not connected and therefore no summon/homelink command can be made. But if you make a command while not connected, and it gets connected within 30 seconds, it will trigger. After 30 seconds, your command expires if no connection was made.@AllenWong Thank you for the update. Question: Should homelink be working? I just updated the app and homelink still doesn't work for me. I don't get a "teslas servers are busy" message anymore, it just doesn't work. The app asks if I'm sure I want to trigger homelink, I hit trigger and it still doesn't work...
Other things to look out for, is the "homelink" icon white or greyed out? Greyed out = homelink is disabled, not nearby and/or not ready. White = homelink is nearby. HomeLink is disabled if you disabled Autopark/Summon (Tesla's requirement).
If it has trouble connecting (i.e. the car icon stays an outline for a long period of time with no sign of connecting to the server), try either tapping on the blue car graphic to force a reconnect, or logging out and back in again.
Ah. This made me look back into my code for the multi-car scenario, and I think I found the bug. I fixed it and sent the updated app to Apple. It will be version 3.3.4. When it becomes available, let me know if it fixed the issue for you, because I don't have multiple Teslas to test with.I do have 2 Model S's on my account, not sure if that matters (it seemed to break Tesla Toolbox's app).
Thanks for the tip. There are quite a few launcher-type apps available. That's why I created these safari shortcuts. Another way of doing it is to put a bookmark icon on your homescreen to a website that redirects to the safari shortcut. This requires that you own a php-enabled webpage.Found a good use for the safari shortcuts.
Using the launcher app I can swipe down from Notification Center and choose my command or 3D Touch the launcher app to add 4 more quick launch commands.
<html><head><link href="http://www.yoursite.com/apple-touch-icon.png" rel="apple-touch-icon" /></head></html>
<?php header("Location: remotes://unlock");die();?>
