1NJ85D
Did anyone try disabling the Dolby surround setting? That makes a noticeable difference in how the sound system functions.
Turning off Dolby does make things better but doesn't solve the problem.
Did I see that 6.2 has a new codec supposed to improve SQ?
Anybody have any experience of this
My issue as an imminent P85D purchaser is whether the UHFS is worth it at GBP2100 given the mixed reviews , but as the standard Audio does not have DAB Radio, the only way is to go UHFS
If you are buying a P85D, the extra cost for the sound upgrade IMHO is a no brainer. It seems there is wide consensus on this thread that it is significantly better than the stock audio system, especially if you use a high quality audio source such as lossless audio tracks via USB.
While wattage isn't a good measure for this sort of thing, the magnitudes are such that you'll likely find this telling:The question is 'why is premium sound so obviously lacking rear power despite the fact that it sports +500 Watts (which is impressive enough)' - and 'can it be fixed by software upgrade or is the hardware set-up wrong?'
Trying to avoid going off-topic too much, but Giz'd post hits home I believe. The rear has half the power of the front, and that's with the upgrade! I honestly think I might go standard + aftermarket. Hopefully 6.2's eminent release will give some details about the sound enhancements. While software cannot overcome this hardware bias to the front of the car, it might be able to help somewhat.
Problem is the console is not upgradable and it will be difficult to fine tune the sound with the OEM hardware, which obviously lacks pre-outs.
The system doesn't lack pre-outs, they're right there on the back of the center display unit. It's just a linux PC running on an Nvidia Tegra 3 chipset with standard PC-like soundcard output. The connectors just aren't standard RCA jacks, instead they're a Fakra-style automotive connector. Companies like Reus have been able to nicely integrate new amps and speakers into the stock system.
Reus uses a converter off the amplified audio to regain discrete to drive the amp(s).
C... If so, all DAB channels would be available on TuneIn over the free 3g...
so long as you have good 3G signal .. which I dont always have, hence my frustration the DAB tuner is only part of the UHFS option.
In the UK at least a 70K GBP car without DAB is really a bit lame, especially as the hardware is <$50 and FM is planned to be switched off in future.
I have no problem with 2100 GBP option for the audio providing it is worth it, and the jury seems out on that at least for some.
Overall I wasn't blown away by the sound .... I'm still torn on whether to get a D or not, though!
