St Charles
Tesla, not TSLA!
What I'm describing is how an open differential works. It always delivers the same amount of torque to both wheels. If one wheel is in the sand, it controls the amount of torque that goes to both wheels. That's why traction control works. By applying the brake to the wheel in the sand, the torque it can generate goes up thereby increasing the torque to the wheel on the road. You don't have to bring the wheel to a stop. You just have to create enough drag with the brake so that the wheel on the street can move the car out of the sand.
Of course you can always limit the performance of the P cars. But I'm talking about fiksegts' contention that Tesla is intentionally decreasing the performance of the non-P Model X. Looking at the power curve he included in his video, the ratio of power to speed up to max power is the same. This indicates that they are applying max torque the entire time.
You just described my point. See we agree. Without traction control one wheel breaks free and this is what happens. Without limited slip and/or traction control you cannot 100% prevent this. TC will cut power/apply brakes to force torque to the other wheel. Since the Model X has traction control, wheel slip is prevented.
The reality is this. The drive units output more enough torque to make a wheel break traction. You even did the math to prove it. Unless you glue the tires to the ground, there is nothing mechanically preventing this condition. This is 100% my point. Traction control is always watching, always measuring, to ensure that the wheels don't slip. This is especially true at launch when the most torque can be applied to the wheels.
Certainly you agree that if the model x had a 5 horsepower motor that only generated 50 ft-lbs of torque at the wheels that it wouldn't spin the tires. So there is a certain amount of torque that will cause the wheels to spin. That is when the tangential force at the road/wheel interface is enough to overcome the friction of the tire. In this case it's about 1250 lbs, which the small motors just can't provide.
Hyperbole is not an argument. The drive units can provide almost double the torque needed to break loose one wheel in optimal conditions. To say nothing about less than optimal traction. You did the math, now apply it to the real world.
Unless someone knows how to measure the behavior of the Tesla Traction Control system, we'll never actually know what's going on. We are just reading incomplete data and extrapolating. That said, I somehow doubt that Tesla is allowing even the small motors output 100% of their capability. That is ultimately what I took away from the video, there is more on the table.
