MarcG
has anyone started adding data to this, because its been several days with no information inside.
Not yet, but I will very soon as I'm taking my big trip up to Oregon at the end of the week.
"But this lower number is due solely to an odd new EPA procedure that slaps a 10-percent range penalty on any electric car that has driver-adjustable charge settings. (Don’t ask.)"
...and wheels and tires make a HUGE difference. + air density of location-coastal vs midland
overall elevation change is important but driving in constant hills does add a little hit too
The mileage rating drops between the 19" and 21" but to be sure, is that due to weight? The contact surface is very close to the same, so its the only thing that I could link to the measurable decrease.
interesting info in this article.
2014 Tesla Model S P85D: First Drive Of All-Electric AWD Performance Sedan...
That explains the 242 and puts the actual rated range at 269...
I hope Tesla changes their rated range calculation for the car. I'd like to actually be able to adjust it back to the normal position where a full charge at rated would read 269. Or even better set my own WH/M.
Range and efficiency
Despite Tesla’s claim of improved efficiency with the dual motors, the P85D has an EPA range of 242 miles, down 9 percent from the 265-mile EPA range of all previous versions of the 85-kWh Model S.
Cars certified under the old procedure, like the S85, get to keep their higher range figures.
Comparing apples to apples, the P85D actually has an old-EPA range of 269 miles, four more than the standard S85.
And in a few months, the P85D will be offered with 19-inch wheels and Michelin all-season tires, which should increase the new EPA figure to 250 miles and the old equivalent figure to 278 miles.
so the range didn't get worse all the sudden, just the EPA added a fudge factor and Tesla didn't make a clear comparison chart.
As I mentioned above these claims about the EPA changing the criteria don't seem to have any citation (unless I keep missing it). It would be nice if someone could point to where this is actually documented.
The procedure has been revised in order to provide new methods for testing Battery Electric Vehicles (BEVs). These methods are intended to both improve testing efficiency and provide a practical testing methodology that can be easily adapted to accommodate future testing enhancements.
I'm wondering if anyone uncovered what the status of "normal" mode is?
Unless I missed something, it's not been seen in the cars despite the original D announcement indicating the car would have "normal", "sport" and "insane." As I understand EPA rules, if Tesla had a "normal" mode, that could be the mode that Tesla used to calculate the D's EPA ranges (and Tesla's own 65 mph numbers). That could be a decent chunk of the explanation why current cars driven in "sport" mode (let alone "insane") are not looking as efficient as rear wheel drive cars despite the better highway efficiency on the Monroney sticker. Of course, that leaves the question, has normal mode been scrapped or for some reason not been activated just yet (and would Tesla be able to send the car out with the stickers based on a mode, normal, not yet active on the car)?
While the claim it was just a straight 10% decrease has no merit (the actual procedure is averaging of two driving modes), the claim that the lower range number is solely because of lower efficiency doesn't have merit either.And breser has pointed out a number of times, in a number of threads, that based on his fairly extensive research, that 10% claim has no merit. I'll try to find his most recent post on that, and come back and link to it.
Edit: breser's post: #3309 here: Tracking P85D delivery thread - Page 331
I agree with this - there is something missing; however, what is becoming clear from the various owners reporting their consumption is that the Wh/mi has gone up with the current version of the P85D. Various drivers are comparing drives with similar if not identical conditions and coming back with a higher number for the P85D. Given this measurement is based on actual driven miles and actual electrical consumption, I think it is almost a certainty that the P85D does not have the range of its predecessor. Perhaps this will be tuned with future updates but for now, unless we get some contradictory data points from new owners I think we have to accept that it is worse.While the claim it was just a straight 10% decrease has no merit (the actual procedure is averaging of two driving modes), the claim that the lower range number is solely because of lower efficiency doesn't have merit either.
This is because if you do even a cursory examination of the MPGe numbers versus the range numbers, the math doesn't work out. First thing is that the combined MPGe is exactly the same at 89MPGe, so unless Tesla limited the usage of the battery, the range should remain the same for the same 85kWh battery.
The next assumption is that it's because of the lower city MPGe (86 MPGe vs 88 MPGe), but that's still only a 2.3% difference. 242 vs 265 miles of range is a 8.7% difference. So even if the test was 100% city (which it isn't), the numbers still don't work out. There's something else in there other than the slightly different efficiency in the city.
Can someone post a link to this article? It sounds fantastic...
I think you may be hitting the nail on the head here.
There has not been any mention of what happened to "normal" mode. That might be the difference.
I don't have access to the SAE standard, so I can't prove it outright, but my assumption is that the change to the requirements (which is well documented in the case of the Nissan Leaf, and "resolved" by removing the 80% charging option there,) is part of the update to SAE J1634, which was revised in October of 2012 and is repeatedly referenced in the EPA documentation (test per, report results per, etc.)
I have access to it now and no there was no change to the spec other than making it so the tests could be completed faster by doing multiple drive cycles in the same test run (each run discharging the battery fully) rather than running a single drive cycle per test run.
