redox
I'm on .139 and not seeing any substantial performance increase.
Same here.
Tesla gets around this by simply saying they recommend 100%. As dennis points out Tesla does tell you to charge to 100% if you need it. The standard doesn't say under what circumstances the recommendation should be. Maybe Tesla is subverting the intention of the standard, but they're certainly following the letter of the standard. But I think the standard is busted and should just be fixed to charge to 100%.
I drove two segments across Colorado yesterday in my P85D that I do now think would have been possible before .139/.140
Here is a summary of results for the first segment:
From Pagosa to Silverthorne, I went up a net of about 1,000 ft in elevation. Because the start is a loss of about 500 ft of elevation in the first mile, and the car cannot accept much of that energy due to lack of regen, the equivalent climb is probably more like 1,250 ft. The route crossed the continental divide 2 times, Wolf Creek Pass and Fremont Pass, and a minor pass, Poncha Pass between the Rio Grande and Arkansas River drainages. Temperatures ranged from 55˚F. to 26˚F. Winds were generally light from a 10 mph tailwind to a 15 mph headwind with most of the drive calm to a headwind. The average was probably a gentle (5mph?) headwind. The car was preheated with "range" mode off, Settings were "sport" acceleration, "standard" regen, and "range" mode on.
I started driving very conservatively with climate control off, and speed as PSL+4 or 61 mph, whichever was lower, never driving over 61. I used cruise control whenever there was no traffic, but went to manual accelerator whenever there was traffic, and for all major speed changes to keep efficiency as high as reasonable. Salida is a good intermediate top up point on charge with a 70A J1772, but adds 5 miles to the route. Coming down Poncha Pass into Salida, the energy prediction graph showed I would make Silverthorne, and my own "Cottonwood Ratio", will-I-get-there, test both showed I would make Silverthorne even with the sun setting and temps cooling. At that point, I raised my max speed to 65 mph and drove on to Silverthorne. By the time I hit Leadville, I had confidence that it would be no problem to make Silverthorne, I removed the max limit and just drove PSL+4. Several sections of that road have a PSL of 65, so the cruise control went to 69 in those areas. Somewhere after Salida, as the sun was getting low and temps were dropping I turned on climate control set to 67˚F. The seat heater was used at a setting of 1 or 2 the whole trip.
With a starting energy was 253 rated miles, I drove 241.3 miles using 67.1 kWh for 278 Wh/mi, arriving with 28 rated miles.
I agree with @breser that EPA testing of EVs should be done at 100% SOC because it makes it easier for consumers to compare EVs. Range is the primary question people have about EVs and the current EPA test results are not as helpful as they could be.
The question of whether or not features like Tesla's Range Mode should be enabled for EPA testing or not is a more difficult one, but in general I would say that if the feature is on by default then the EPA should test the car that way, if not on by default then don't. Most people don't change the cars default settings, though certainly some do.
Even though there are several stretches of 45 and 50 mph PSL on this route, with the equivalent of 1,250 ft of elevation gain, and crossing three passes, I drove this route before with similar driving style and had no hope doing this drive with .113 firmware. I was using what most would consider hypermile techniques (see graph below), but before .139, I don't think that there is any way I could have done 241 miles with 28 miles left in the battery!
I don't disagree that it should be 100% - its just the "why" we differ on.
It should be tested against 100% because they are applying the same logic in Jeromes message - its a logical setting for a driver seeking range. If on the other hand, we are to use the same logic being applied to the range thought process you noted, the default setting for a Model is battery charge is 90%, not 100%. Not only is 90% recommended everywhere you look for a baseline in their literature, if one charges to 100% more than a few days in a row, the car asks you if you're on a road trip and suggests a lower setting to protect battery life. If that isn't saying that 100% is to be avoided as a default setting, I don't know what is!!
By the way, there's a Lab hair on your 17". :biggrin:
Date | Distance | Time | Avg Speed | RM Used | kWh Used | Wh/mi | Avg Temp | Cabin | Roads | Weather | SW Version |
1/26/15 | 9.0 mi | 7m18s | 73.97 mph | 12 | 3.4 | 370 | 10ºC/50ºF | Seat Heater (2) | Dry | Cloudy | 6.1 (2.2.113) |
1/27/15 | 10.1 mi | 8m34s | 70.74 mph | 12 | 3.3 | 327 | 17ºC/63ºF | None | Dry | Cloudy | 6.1 (2.2.113) |
1/28/15 | 9.6 mi | 7m51s | 73.38 mph | 13 | 3.6 | 378 | 17ºC/63ºF | None | Dry | Sunny | 6.1 (2.2.113) |
1/30/15 | 9.6 mi | 7m48s | 73.85 mph | 12 | 3.4 | 359 | 12ºC/54ºF | Seat Heater (1) | Dry | Cloudy | 6.1 (2.2.113) |
2/2/15 | 9.7 mi | 8m01s | 72.60 mph | 11 | 3.3 | 343 | 12ºC/54ºF | Seat Heater (1) | Dry | Sunny | 6.1 (2.2.113) |
2/4/15 | 9.7 mi | 8m14s | 70.69 mph | 9 | 3.0 | 314 | 14ºC/57ºF | None | Dry | Cloudy | 6.1 (2.2.139) |
2/5/15 | 10.0 mi | 8m19s | 72.14 mph | 10 | 3.1 | 308 | 14ºC/57ºF | None | Dry | Cloudy | 6.1 (2.2.140) |
2/6/15 | 9.8 mi | 8m24s | 70.00 mph | 10 | 3.0 | 302 | 15ºC/59ºF | None | Dry | Cloudy | 6.1 (2.2.140) |
More data from my commute to work this morning - definitely seems to be consistently lower with the latest updates (yes I'm still in INSANE mode with RANGE MODE on):
Date Distance Time Avg Speed RM Used kWh Used Wh/mi Avg Temp Cabin Roads Weather SW Version 1/26/15 9.0 mi 7m18s 73.97 mph 12 3.4 370 10ºC/50ºF Seat Heater (2) Dry Cloudy 6.1 (2.2.113) 1/27/15 10.1 mi 8m34s 70.74 mph 12 3.3 327 17ºC/63ºF None Dry Cloudy 6.1 (2.2.113) 1/28/15 9.6 mi 7m51s 73.38 mph 13 3.6 378 17ºC/63ºF None Dry Sunny 6.1 (2.2.113) 1/30/15 9.6 mi 7m48s 73.85 mph 12 3.4 359 12ºC/54ºF Seat Heater (1) Dry Cloudy 6.1 (2.2.113) 2/2/15 9.7 mi 8m01s 72.60 mph 11 3.3 343 12ºC/54ºF Seat Heater (1) Dry Sunny 6.1 (2.2.113) 2/4/15 9.7 mi 8m14s 70.69 mph 9 3.0 314 14ºC/57ºF None Dry Cloudy 6.1 (2.2.139) 2/5/15 10.0 mi 8m19s 72.14 mph 10 3.1 308 14ºC/57ºF None Dry Cloudy 6.1 (2.2.140) 2/6/15 9.8 mi 8m24s 70.00 mph 10 3.0 302 15ºC/59ºF None Dry Cloudy 6.1 (2.2.140)
Infiniti, for one, absolutely lets you override adaptive cruise... just by holding down the cruise-on button. Their sensor (G37 & EX35) gets dirty very easily and thus they tell their customers about this as a way to work around the calls of "my cruise is unavailable".
Huh. Learn something new every day.
Is there a driver warning or alert come when it disables? Does the car show anything different on the instruments while you are in the non-adaptive cruise?
Are these Infinitis equipped with automatic emergency braking/panic stop?
Inquiring minds want to know...
Walter
Interestingly enough Tesla has a range calculator. That calculator shows that at 70 mph one can go 261 miles and at 65 mph one can go 285 miles. So basically Marc is getting exactly what Tesla said he should get @70 so I would assume he can get the 285 miles @65mph that was originally advertised.For MarcG, at 302 wh/mile he can supposedly go 260 miles at 70 mph. Now that is really incredible if he can actually demonstrate if that is possible.
Now that also bring up the possibility that range could be even more, perhaps 275 miles? - when driven at 65 mph, but I didn't see a single run from Marc at any speeds lower than 70 mph
over 20% reduction in consumption!! Yay for TM and thank you Marc for continuing to share this data!
Your Questions Answered | Tesla Motors
I do have some longer runs at lower than 70 mph but they were pre-2.2.139, so I'll post new data after my long ski trip this weekend.
So at 70 mph I should be getting right around 260 miles. Looking forward to testing that!
Marc, it might have been asked; however, are you running 19" wheels?
Indeed. I chose not to get 21" wheels for 5 main reasons:
1. Range reduction
2. Rim damage (bad CA roads)
3. Tire wear
4. No all-weather 21" tires from Tesla (summer or winter only)
5. Cost
