One mode/display in the Leaf dashboard shows estimated time to recharge based on how far from "full" you are at the moment.
I find that somewhat handy.
So you can quickly plan how long you might need to stay somewhere while recharging.
What's striking to me is how slow this charging rate is. At 240V, 2.5 hours to get ~25 mile charge.
What's the LEAF current rate at 240V? Specs say the home charger needs a 40 amp circuit so continuous draw will be lower than that.What's striking to me is how slow this charging rate is. At 240V, 2.5 hours to get ~25 mile charge.
The current generation of the Leaf has a puny 3.3kW charger, so about 14 amps.What's the LEAF current rate at 240V? Specs say the home charger needs a 40 amp circuit so continuous draw will be lower than that.
My experience is that my LEAF draws a maximum of just over 16 amps at 240 volts and adds about 14 miles per hour of charge. It has been noted that the LEAF will draw a maximum of 12 amps at 120 volts which adds about 5 miles per hour of charge.What's the LEAF current rate at 240V? Specs say the home charger needs a 40 amp circuit so continuous draw will be lower than that.
