If someone other than Tesla considers making a Roadster battery pack (as has been suggested could be doable), I would be very interested. 24 kWh without advanced cooling system could be enough for me if the performance/cost is good.
Earlier on this thread a light weight battery has been discussed. This could make the car faster, give better handling and hopefully be much less expensive. Of course it depends on what battery and cost Tesla comes up with.
If the battery weight is reduced by 300 kg/600 pounds, the 0-100 km/h speed could be reduced by 0.9 seconds.
Car Acceleration
(assuming the calculations are correct and that the back wheels are wide enough to avoid spinning)
It is a bit extreme weight reduction right now, but perhaps not in the near future.
The 24 kWh battery pack used in the Nissan Leaf can pull 200 kW for 30 seconds according to a youtube video
My Civic EV Electric Car Project Part 14 Explaining the Batterys - YouTube
(I think it was this)
It is a cold climate where I live in Trondheim, Norway. the speed limits are low and I don't need to do fast charging, so an advanced cooling system should not be required for my usage.
I do have a Roadster that could be used as test mule, have access to some equipment/skilled people and >100 kWh of EIG cells ePLB-C020B (inside battery packs of 10 kWh each), perhaps also Nissan Leaf cells.
We repaired the PEM in my Roadster in 2011. I was the "project manager", it was the skilled people mentioned above that did the work. I know a PEM repair has been done later and reported in this forum, still I show some pictures from inside my PEM:
Dropbox - RepairPEM
Reason for repair: Car was exported and therefore not under warranty.
I don't think crash tests are required for a small series car like the Roadster.
