If you were Tesla, how would you try to transmit the performance of the car to world?
The offer to existing P85D owners is to upgrade them to ludicrousness without changing their pack capacity. The fuse is very accessible in the pack (not sure about the contactors) so I can easily believe that this can be done at the SC, without any swapping. Various trusted sources have told me that the resulting P85DL makes 0-60 in 2.9s instead of 2.8s for the 90kWh pack. Elon's blog article says that the performance and capacity changes are "unrelated" and he's almost right, though there is apparently a tiny performance difference between the P85DL and P90DL.
Fair enough.
1500 amps * 350 volts yields 525 KW
525 KW / 750 W/HP yields 700 hp so the ludicrous upgrade will allow the battery to deliver roughly 700 hp
I guess those that are interested will run it up the flag poll with Tesla (upgrade the car for free given you said you would deliver 691 hp yet your battery was limited to much less) and let us know how that conversation goes. If history is any indication, it will fall on nearly deaf ears.
Of course all of this misses the most interesting thing in the whole call... Elon said that a car like this should have staggered wheels and that it makes 1g lateral when staggered and with Michelin Pilot Super Sports. I don't think that's a slip of the tongue... $100 says they're about to go back to staggered configuration for the P85/90D, but with Pilot SS tires rather than PS2, because Michelin are finally making the Pilot SS in the 265/35R21 size they need for the rear wheels.
The one thing that I have not heard a clear definition on is what constitutes an "existing owner" in terms of eligibility for $5k + labor ludicrousness. Do you have to have had the car delivered? Built? Order confirmed? Nobody seems to be sure.
Michelin Pilot Super Sport vs. Michelin Pilot Sport PS2 - Make Driving Fun with Performance Tires Wheels | Tire RackForgive a newbie question: what are the advantages of Pilot SS tires over PS2s?
The following are some of the key advantages of the Pilot Super Sport compared to the Pilot Sport PS2:
- More dry grip
- Improved fuel efficiency
- Extended treadwear
- Improved wet traction
- Faster steering response
- Reduced tire weight up to 10% compared to competitors
In addition, Michelin has priced the Pilot Super Sport a bit below that of the old Pilot Sport PS2 in many sizes, making the newer tire a great deal!
Treadlife Warranty:
6 Years / 30,000 Miles
Half mileage for rear if different size than front
Did they say how the 1/4 mile time was impacted? The reason I ask is I find it hard to believe that the 90 battery would draw less current than the 85. The use of silicon in the anode increases capacity but has several tradeoffs. First, anodes that contain silicon experience far more size delta when charging vs graphite only anodes. This makes them more susceptible to fracturing and it's particularly worse when you fully charge a lithium ion battery with a silicon anode. The other tradeoff off is even though the capacity increases, the maximum discharge rate decreases. Maybe they're only using a tiny bit of Silicon so these tradeoffs are very very minor, but I can't imagine the 90 battery would provide a high discharge rate.
I can tell you this with certainty - my DES confirms that my car is eligible and it was in production (testing actually) when the announcement was made. Hopefully that helps a little.
But there will be voltage sag at those types of current levels. You can guarantee that the pack will not be at 400V under 1300A+ of load.I think the following math is closer. We know the peak voltage of the pack at 100% SOC is 402V (let's round to 400V for easy math). That means:
Old fuse: 1300A * 400V = 520kW
New fuse: 1500A * 400V = 600kW
It's quite possible that the P90 cells have lower resistance so voltage does not sag as much under load. More voltage = More power at the same current levels.Sorry I don't know any more details. Given the identical pack voltages and current limits it's not obvious where the 0.1 difference would come from.
One of the wonderful advantages the blog post didn't include was:
I went thru two sets of the PSS2's in 12,000 miles, which saved me ~60% off the replacement set each time.
