I got a new 2023 MYLR 7 seat 20inch induction wheel.
Location Alberta,Canada.
Temperature -11degree celcius.
Battery from 50% to 4% at only 95km
Is that normal???
I was expecting a 20%-30% maximum range reduction due to cold this is over 50%
Thank you
Was this is a single drive cycle or spread out across several drives?
Heating up the interior takes a lot of battery power. This is particularly evident if you take multiple short trips. If you’re taking a long trip, preconditioning (while plugged in) can improve your range by bringing the cabin up to temperature from grid power instead of battery power.
Once outside temp is well below freezing, the efficiency of the heat pump is reduced. The colder it gets, the less efficient it becomes until it reaches ~parity with straight electric resistance heat (coefficient of performance = 1).
Where did the expectation of a 20-30% decrease come from? In my experience, it’s more like 50% around down and 30-40% on the highway. My experience is limited to non-heat pump cars, but again, the two approach parity in very low temperatures.
At -11C should fully precondition the Tesla Model Y before driving; hopefully using Level 2 (240V) and 32 amp or greater charging, for ~30 to 40 minutes.
This is a great recommendation *if* you’re plugged in. If not, it’s basically a waste of battery power.
Check tire pressure, male sure tire pressure is correct per the label on the A pillar by the driver's door or even a bit higher.
Great recommendation. Tire pressure drops as temperature drops, so it’s important to check and top off as winter settles in.
Turn on Recirculate Cabin Air under Climate Control settings. (If the windows fog on the inside you may have to turn Recirculate Cabin air off but if you leave the Climate Control in Auto this should not happen.)
In my experience, while this can reduce cabin heating energy, it’s almost always a recipe for instant window fogging. It’s probably best to leave it in auto even if it uses a little more energy.
Use the seat heaters and the steering wheel heater; dress warmly.
The things that have the greatest impact on range include:
Speed (lower your average highway speed by 10kmph for improved efficiency and range.)
Wind and snow covered roads, wet roads will reduce range as will increases in elevation.
Use A Better Route Planner (ABRP) (available on the web and as a phone app) to plan your trip. Stop to use a Supercharger or DC Fast Charger where ABRP indicates you should stop on your trip.
Precondition for Supercharging by always being sure you enter the next Supercharger along the route in the Tesla Navigation system. The Tesla Model Y will start preconditioning (performing an extra degree of warming of the battery pack) until the battery temperature reaches ~50C for optimal (fastest, most efficient) Supercharging. Preconditioning for Supercharging will require a fair number of miles/time of highway driving in colder temperatures. to reach the optimal 50C battery temperature for Supercharging.
