Model S at Nurburgring: Here's What A Tesla Model S Can Do Around The Nürburgring
they hit reduced power mode after 3 minutes....
Also putting it on Low regen tends to keep the acceleration limiter at bay for a little longer.I think he would have been impressed more if somebody would have told him to keep suspension in the low setting all the way. It was in standard for most of the time, except that it switched to low (at 2:07 mark) when he tried to keep up with the GT3 RS "going full chat"
I think it's battery protection, as discussed in one of the other threads. Which is a bummer, because the "fix" would likely be to use a different chemistry -- likely with less range.In spite of what is mentioned in this article, the power limiter is most likely triggered by PEM and/or motor temperature, as continuous rating of the motor is 69kW and the rating of PEM is most likely optimized around this point as well. I bet that having two motors and two PEMs will make the battery limiting, rather the motor/PEM, resulting in higher output for a longer time.
My interpretation of the prior discussion is that improving the cooling to the point where it made a significant difference (vs. Tesla's current design) would add at least another 5 digit sum to the vehicle price tag. Or would require some influx of chemicals (between runs at the track, or such) that would make it impractical for usage by most people.Why improved cooling of the battery would not help?
You guys are aware that this was a S60, not a P85 or P85+, right?
