ccutrer
How do we know the same charger is present in all vehicles? Did you check the part number on multiple X's? I'd say it's just as likely that Tesla finally relented and decided they'd be okay with replacing the original charger if you decide to upgrade to a 72A charger. While "72A is only 50% more than 48A" sure seems like the price should scale linearly, so it's not much of a loss for Tesla to just do 72A, that's not always true. Especially on the cutting edge, it's often true that as you get closer to the edge, you're running closer to limitations, and prices can start to scale exponentially. For example, a typical home electrical service panel rated anywhere from 100-200A will cost you $100-200 (materials: Square D Homeline 200 Amp 30 Space 42 Circuit Outdoor Surface Mount Main Breaker Plug-On Neutral CSED-SC3042M200PS - The Home Depot). But to go larger, you have to go to a 400A (there's no such thing as a 300A; you just put smaller breakers in a 400A panel). Which costs ~$700. Square D Homeline 400 Amp 30-Space 40-Circuit Main Breaker Outdoor Combo Surface Mount CSED-SU3040D400CB - The Home Depot.
