Lonnie123
Not sure how reducing the motor to 180hp would reduce cost. All they'd have to do is diminish the power going into the motor via software. These aren't ICE powerplants we're talking about, where making a lot of power requires semi-exotic, expensive materials. I agree on most everything else you listed though.
Smaller motor = lower cost, right?
If they are trying to keep their margins high, shaving every little bit of expense here and there will make a big difference. If they can save $50-100 on every single motor x 500,000 a year... It isnt a trivial cost.
I am no electrician/mechanic so I am purely speculating and maybe the cost difference is totally negligible. But for someone coming from a Corolla, jumping up to a 180hp motor would be an amazing increase. If it meant getting the car for cheaper I would certainly opt for a smaller motor.
The tesla's will have tons of upgrades and options... There could easily be a base motor, then a P verison, then a D verison, then a PD version for those who have the need for speed. Why not start with a competitive motor (3 series starts at about 180 if I remember right) and then allow for upgrades?
- - - Updated - - -
To me, hubcaps scream "cheap." The only reason I could see them on the Model 3 or any other EV is for aerodynamic or efficiency-enhancing reasons. If they serve a justifiable purpose, then that's understandable, but if the only purpose is cost-cutting, I think that would detract from the premium image Tesla is trying to maintain. I think flush-mounted (but not power-retracting) door handles are likely. In terms of power output, I don't know how much would be saved by going with a 180 hp vs. 250 hp motor. Other than a slight difference in material costs, I don't see the big savings. The output could be modulated by software. Maybe limit to 180 hp (134 kW) in "Eco" mode, and give the full 250 hp in "Performance" mode.
To me Rims scream "Expensive" and massively unnecessary. The ultimate in vanity... You are paying hundreds/thousands to get a certain look with no added functionality. To each their own, but I would be perfectly fine with an "Electric Corolla" for the Model 3.
Getting the car down to $35k will require shaving small amounts of costs here and there. Aside from the big things I wrote in my first list, shaving $50-100 in 10-20 different areas is going to go a long way in doing that.
- - - Updated - - -
Not using aluminum is going to increase the weight quite a bit and have a significant range impact. I don't see how they'll get above the 200 mi rated range target.
I believe Elon said the 3 will not be made out of aluminum, but perhaps some kind of alloy. Make what you will out of that
