JRP3
Hyperactive Member
The GM-developed process is ferritic-nitro carburizing (FNC), a form of case hardening. FNC is a gaseous process that “diffuses nitrogen and carbon into the metallic part” following production machining of the rotor's friction surface, explained Jim Webster, a GM brake engineer who helped spearhead the program.
The rotors are super-heated at 560°C (1040°F) for up to 24 hours within a nitrogen-rich atmosphere. The nitrogen atoms bond to the surface of the steel rotor, hardening it and increasing its strength.
The FNC process lays down a 10-µm-thick transfer layer across the entire rotor surface, including the center “hat” section and inside the central cooling vanes of ventilated rotors. (Ten microns is roughly 1/10 the width of a human hair.) The resulting friction surface is significantly more durable than that of a rotor without the FNC treatment, while remaining virtually impervious to corrosion and rust.
GM aims to double brake rotor service life with new FNC treatment - SAE International
