benjiejr
Technogeekextraordinaire
After about 5 weeks and a little over 2600 miles with my P85D, I'm averaging 407 Wh/mi. I guess I've been having too much fun!
Starting over with a P85D in 19" winter tire:
Janurary 2015:
4,255 mi 1,662.8 kWh 390 Wh/km
Life time = same as I got the car on January 7th
Why did you specify distance in miles but specify "efficiency" in Wh/km?
I'm assuming you meant 4,255km, which is still a TON of distance traveled!
Does average Wh/mi affect projected range? If not, why not?
I'm in TX, during the summer the A/C doesn't add significantly to the Wh/mi.
I agree that it doesn't have a significant impact most of the time. But when its >110 out, energy use from HVAC goes way up (and doesn't drop much once the cabin is cooled down…)
Also, I've had HVAC mostly off for the winter (except on colder mornings under ~45 or so)… There is a noticeable improvement in Wh/mi when its off vs on… about 8-10 better for the same drive… Not really significant, but noticeable.
Precooling and preheating takes away most of that. When it's hot out and you can't pre-cool, just turn the temperature up so that it doesn't run full blast at first (clue is there are only two fan blades lit, and don't use range mode). It will still feel cool. Then when you start to feel hot lower the temperature by 1 C. Repeat until you're down to the temperature you want.
