rolosrevenge
Dr. EVS
This is going to drive grid defection. At $40/month (!!!!) that's $480/year.
Suppose you use 1000 kWh/month evenly spread across the days, and you use 1/3 of your power at night. I did some casual research, and you can get 12 kW of battery for $2580.
That's equivalent to 6 years of fixed charges at the rates you are paying. The batteries should last that long.
At such outrageous basic connection charges, anyone with low usage per month should go off grid immediately -- it's a no-brainer.
Here where I am, my fixed charge is $16/month or so. This isn't going to drive people off the grid. $40/month WILL, and VERY FAST.
High fixed charges encourage efficient households to go off-grid. This is not well-thought-out, as this will induce a death spiral for the utilities.
I will further note that the drug-addled lunatics at HECO in Hawaii are proposing a $50/month, or higher, fee:
As Hawaii Prepares for Utility Reform, the States Solar Industry Sheds 3,000 Workers : Greentech Media
This will make local batteries a no-brainer and completely eliminate the grid on Oahu *very, very quickly*. It is a plan for accelerated bankruptcy. The government may intervene to save HECO from its own management; except for that possibility, I'd be very tempted to short-sell Hawaiian Electric.
Remember, to go off grid and maintain the same level of reliability, you'll probably need to size your solar to produce about 5-6 times your daily needs and batteries large enough to store about 4 consecutive days of usage. Then the economics don't look so good.
