I've mentioned this in other threads, but several energy companies are indeed changing their approach. For the past 5 years or so, my co-op has changed its approach to fixed cost vs. variable cost. It has raised the connection / meter fee (from an original $17ish/month when I started a number of years ago to a current price of ~$40/month, while lowering (or at least attenuating the increases of) the variable costs. This helps to solve the primary argument that non-solar customers subsidize solar customers' use of the grid as a battery.
The downside of this approach is that anyone who consumes less than 1,000 kWh/month sees a higher bill overall, but it does bring into line the fixed costs of a grid connection and the plant maintenance & depreciation costs. You could say that under the usage-based model, I'm subsidizing the farmers who want a meter at a lean-to, 3 miles into their field, for $5/mo.
There's a concept in the power industry called "coincident peak." It really doesn't matter much if you use 3x your usual amount of power at midnight; there's a lot of surplus resources (generation, transmission, ancillary services) to handle that. What is costly is when a customer's peak demand lines up with the system's peak demand. If we charged people based on coincident peak rather than non-coincident peak, the results would be markedly different.
We can come up with all kinds of rate strategies that make sense for aligning charges to the state of the grid, such as charging more for "coincident peaks" than off-peak peaks. However, the fundamental problem is getting customers to understand it and having any predictability to consumer utility bills. In addition, most consumers don't have the ability or willingness to shift their load.There's a concept in the power industry called "coincident peak." It really doesn't matter much if you use 3x your usual amount of power at midnight; there's a lot of surplus resources (generation, transmission, ancillary services) to handle that. What is costly is when a customer's peak demand lines up with the system's peak demand. If we charged people based on coincident peak rather than non-coincident peak, the results would be markedly different.
That is a very important point. The typical home solar impact it to create a negative peak (pumping solar power into the grid) when the grid is at its peak draw, and to have a normal peak (usage) when the grid is off-peak. Home solar tends to reduce the "coincident peak," which is good for the grid, not harmful.
You and I have a different idea about what "overly penalized" means for TOU customers. PG&E's EV TOU E-9 tariff has total bundled prices/kWh that vary from 6.5c/13.0c/34.5c up to 18.5c/33.5c/55.0c depending on your monthly usage. Those three prices are Summer Off-Peak/Part-Peak/Peak respectively. The price range is pushed artificially low at low usage and Off-Peak to encourage vehicle charging between midnight and 7am. 6 months ago that same Summer Off-Peak number of 6.5c was 4.85cents.The utilities generally don't want the idea that customers will shift load, to be understood in my opinion. Still thinking about SRP, for example, they acknowledge 86,000, of 1mm, customers signed up for TOU (in the 127 page report). That's pretty high, even if they are overly penalized with a $.20 on-peak rate (relative to $.11 base). There's very little promotion of TOU, accept word of mouth and EV forums. That's been my experience.
TOU can be defended without subsidy. The effect of extreme dilution of net-metering policies, as they contribute during "coincident peak", can leave the base rate payer as the subsidized party. They push peak load. It's sad, but I think utilities prefer this, and that savvy customers just shut-up and go away. Higher peak load means the justification for more bonds, or more ROE on new assets. The advisory (ratings) relationship works this way, beyond what I bet many utility managers understand.
Ideally, people won't have to think about it. They'll have a little computer tucked away someplace that's pushing as much use as it can into the day time hours to fit well with solar production. Dispatchable demand would be good for the utilities too.This is one of the main reasons I don't think the grid will ever go away. Most people don't want to be bothered with altering usage to get slightly better economics. They definitely don't want to have to worry about producing and storing adequate power constantly, let alone fixing anything that should go wrong.
Anywhere in PG&E territory that you have a need for a lot of A/C you should get a separate meter for EV charging off peak. There is a pilot program right now that allows the EVSE to be a sub-meter so you don't have to go to the expense to install a separate utility meter at your demarc. They use the SmartMeter data to subtract your vehicle charging from your house meter.We too live in PG&E territory, but in the hot Central Valley. TOU makes absolutely zero financial sense for us because come summer (anywhere from late May to mid-June) the overnight lows are 70-75 and the daytime highs can reach 108-110+, sometimes as early as 11AM on those scorchers. We have about an eight-week window out of the six-month "summer" rate season where we might be better off with TOU rates rather than the standard rates. Our rooftop solar at least allows us to remain in the baseline tier for the entire year.
I think that with any blanket approach to utility charges and assessments and fees, there will be winners and losers. While regrettable, it is inevitable.
OK, I see what's going on. Installation prices are still excessive. The all-in cost in Germany is $2.80/watt, but in the US it's $4.87 a watt.neroden, note that the overall revenue to the co-op didn't go up. It redistributed pricing based on the actual cost to maintain the grid. Those who used less than 1,200 kWh saw their bill go up, while those who use more than 1,200 kWh saw their bill go down. Usage charges were either reduced or growth-arrested to compensate. It's just a reallocation of fixed vs. variable costs.
So when you look at off-grid vs. on-grid, let's look at those who consume an average of 1,000 kWh per month. A 9 kW solar installation will generate 12 MWh/year here, which would be what's needed -- however, you'll really need some excess capacity for those stretches of overcast days, so let's just assume a 20% buffer, bringing you to a 10.8 kW system. Solar installation here is $4/W.
OK, so that's the second thing going on: due to your location, you have really, really cheap grid electricity. There are vast swathes of the country where it doesn't go below 10c/kwh. Not far away from me, I've heard quotes over 20c /kwh. And we already have fixed charges, they're just not as large as yours.Usage here costs 9c / kWh (my parents, 3 miles away, pay only 5c / kWh).
So basically, the fixed charge is high but you have ludicrously cheap variable charges. A small increase in your grid rates overall, and the calculation starts mitigating in favor of going off-grid.At $40/month meter charge and 9 cents per kWh, you're looking at a yearly power bill of $480 + 1080 = $1560. Payback on this, then, is just over 16 years,
When people pay $100/month for cable&internet and another $50/month for cell phones, $40/month to have access to buy or sell power on the grid is a great bargain.
