The temperature is positive!!! The temperature is positive!!!
1C.
The cold is supposed to break after toady - the long term forecast shows highs of 0 or better for every day going forward. It will be nice to see what energy usage you get in above zero temps - I have owned my P85D for 9 weeks but have almost never driven in above zero conditions.
Not quite the coldest on record - the coldest in recent memory - or here in Toronto since YYZ opened. Apparently 1934 was colder as Lake Ontario completely froze over which is very rare.Coldest February on record. Not a single moment above freezing in the whole month, and no January thaw ether. Really glad that's over!
It's not hard to believe that this past February was the coldest on record in southern Ontario, and it's been touted as such for Toronto.If you're hearing that, it's likely because readings from Toronto's Pearson Airport definitely show as much, but Weather Network meteorologist Dr. Doug Gillham says the city as a whole has seen colder days.
"The average temperature [at Pearson] of -12.6[SUP]o[/SUP]C shattered the previous record of -10.8[SUP]o[/SUP]C set in 1979," Gillham says. "It should be noted, though, that in Downtown Toronto where we have a longer record of weather data, February 1934 was even colder than this year."
In fact, it was so cold in February 1934 that Lake Ontario is said to have frozen over completely, the only time in 100 years this is said to have occurred ... although without satellite data, it's near impossible to verify that. The lake has not frozen over since the U.S. National Oceanic and Atmospheric Administration began keeping records in 1973.
"In many places with records that go to before 1934, this February will take second place to 1934 (such as in Ottawa)," Gillham says. "However, Timmins is an example of a city where this February was even colder than 1934."
Ottawa recorded its coldest-ever February, with an average temperature of -16.8 C, shattering the former record set in 1979.
Assuming that I could get VT to work is that something you could log - daily amount of charge?
The Ontario Hydro peak rate is 14 cents and the evening rate is 7 cents per kwh BUT then on top there is a Delivery charge, Regulatory charge, and Debt retirement charge and then HST. This all then averages out to more than 18 cents per kwh. I installed an auxiliary digital meter into the line to the HPWC so I know exactly how much went to the car.
