LOL. My thought is that if the regen was actually lowered with every thread (after a firmware release) that says it was, there would be no regen leftOne word: psychosomatic
Then more recently, they cut the regen down from a max of about 90 kW to a max of about 60 kW. I assumed it was to extend battery life, or something, although superchargers are able to put charge into the battery at a greater amount.
still awaiting word from engineering on this. anecdotally, i should point out that before saturday, i had repeatedly remarked about how i almost never needed to use the brake pedal thanks to regen, but since then, i am noticing i need to use the brakes quite often (comparatively speaking).
more to come...
This whole discussion would be moot if they would simply add an option for stronger regen. That Would make a lot of folks very happy at no cost to everyone else.
more to come...
If you're driving a D, the variability in the regen onset ramp can easily mess up your timing and have you reaching for the brake pedal with some frequency. See my post (#20) earlier in this thread.
Are you sure about that? In two years of firmware updates since 4.x I never saw anything greater than 60kW, certainly not 90kW.
In fact there is a whole thread asking for the regen to go above 60kW:
Firmware feature request - Option for Regen 60 kW?
Yes, I am sure. It used to go to 90.
I never saw it. What version did it go to 90 on. My earliest version was 4.1.I've never seen any other reports of that I wonder if anyone else saw it.
I don't recall ever seeing the 90 kW regen you speak of. Was this something they changed after Founder but before Signature?Then more recently, they cut the regen down from a max of about 90 kW to a max of about 60 kW. I assumed it was to extend battery life, or something, although superchargers are able to put charge into the battery at a greater amount.
more to come...
