Installed .179 this morning and after the install finished it was back at 79A. Think I just had a couple lucky connections.
My P85 has always charged at 79/80 with an 80A pilot current (according to VisibleTesla). I've never once seen it go to 80/80. I asked service about this and they told me it's a rounding error and nothing to be concerned about. I haven't worried about it since. My voltage drops from 245v at 0A to about 237v at 79/80A.
But just to be clear, you know that's not what we're talking about happening here, right? We're charging at 79/79. (Check the video to see what I mean if you like.)
I saw mention of 79/80 versus 80/80 and figured it wouldn't hurt to add a data point.
The Charging Current offered is encoded as the width of the pulse (PWM Pulse Width Modulation).
I think you might have hit on the answer. When S detects voltage drop to something below 240 it dials back current draw assuming something is starting to stress (heat).
Anybody report this phenomenon when voltage is constantly at or above 240?
Yup. My impression was the HPC was installed with a 90A breaker and #6 wire. The mismatch of the wire and breaker was what drew my attention.
Actually, the HPC was installed with #2 wire. When I removed it and installed the HPWC I couldn't get the #2 wire to fit into the HPWC's terminals. So I replaced it with something smaller. But I was wrong when I said above that I used #6. I just checked and while I can't read the markings on the wire it is clearly much larger than #6. So it's most likely #3 as specified in the HPWC installation instructions. That means all I need to be totally up to code is to replace the breaker with a 100A one. But that seems like a lot of bother for a circuit that can never go over 80A. Isn't a smaller breaker actually slightly safer; won't it trip sooner if there's a problem? I suppose it's more likely to fail and trip too soon but that seems unlikely and wouldn't do much harm anyway.
My understanding is that you could end up with a nuisance trip, and might end up with stressing the breaker by running it that close to it's trip point for extended periods. Best to just follow code instead of improvising.... Isn't a smaller breaker actually slightly safer; won't it trip sooner if there's a problem? I suppose it's more likely to fail and trip too soon but that seems unlikely and wouldn't do much harm anyway.
... That means all I need to be totally up to code is to replace the breaker with a 100A one. But that seems like a lot of bother for a circuit that can never go over 80A. Isn't a smaller breaker actually slightly safer; won't it trip sooner if there's a problem? I suppose it's more likely to fail and trip too soon but that seems unlikely and wouldn't do much harm anyway.
NEC states that the "protection device" (breaker) must be sized at 125% of continuous loads. Another part of the code defines "continuous" as "over 3 hours". 80*1.25=100. Therefore, you must have a 100A breaker on an 80A HPWC to be code compliant.
Same thing applies to the wires.
That's why all the charts in the US version of the HPWC install guide show 100 amp breaker for 80A DIP switch setting, and so on and so forth.
There seems to be some speculation the 79A issue affects all D.
Just to add a single data point:
I picked up a P85D yesterday. This car reaches 80A correctly after ramp up, and stays there. V6.1 (2.2.179), car had been outside for hours on 40F ambient, spent the prior 3 days in colder temps. Then driven 70 to 80 for 45 minutes, then sat for an hour, then charged. Beginning SOC somewhere around 1/2 to 2/3rds, charged to 90%, I did not watch every minute of the charge... as mentioned, after ramp, consistent 80A.
P85D Order Dec 09 2104; Production Feb 09 2015. Delivered Mar 2, 2015. Pearl White | Grey | Obeche Gloss | Black Alcantra | Next Gen | Pano Roof | Tech | Air Susp | Prem Sound
Contents of above post © 2014, 2105 Danal Estes. All rights reserved. No part of this post may be reproduced, stored, transmitted, or disseminated in any form or by any means without prior written permission.
My P85D was one of the December delivery, started first week of production cars. When charging it shows 80 amps available and typically flutters between 79 and 80 amps current. The voltage is pulled down to 220 +/- a volt, typically. I've seen it settle for a few seconds at both 79 and 80. Definitely doesn't cap at 79 nor sit cemented at 80. This may well be charger specific for me. Haven't tried another charger at 80 amps.
From my experience that's perfectly normal.
Yup, is what I thought too. Providing as a data point of another P85D that isn't showing a 79/79 issue as was described earlier in the thread, since there were comments that all D's were affected.
I'm guessing this affects a bunch of cars...possibly even all of the Ds. ... I'd be shocked if this is limited to a small number of cars.
