Folks, I was responding to
@gottagofast where they indicated that time had to be added for Superchargers off the long route.
My response was that I've never seen one over 3 minutes. Since that statement I have indeed thought of one and there have been a few examples shown where there are indeed a few, but they are few and indeed far between.
But back to the original splintered subject, if you follow the Tesla Nav's suggestion to charge doing long trips, it will get you there. The Tesla Nav is very conservative and now takes a lot of things into consideration, but its goal is to remove any range anxiety and "get you there"
There are optimizations that folks found many years ago that can get you there faster. Indeed, they come with higher risk and a higher level of range anxiety. They aren't for everyone, but they do significantly reduce the time of travel in an EV.
The basic concept is to charge at the best part of the batteries charging curve. Find a curve or just record the numbers when you next Supercharge. How long does each 10% of the battery take 0=10%, 10-20%, 20-30%? You will find that there is a significant difference in each one of the 10% time and 90-100% is stupidly long. While 0-10% is amazingly short.
So why don't I charge from 0-100%? that last 10-20% just takes too long. It takes about as much time as it does to get from 0-80%
And 0% may be a little (or lot) too low for folks, so let's say 5%, or even 10% to 80%. That's what the Tesla Nav system is going to do.
After doing a little math, it ends up that, contrary to normal belief, (and trust me, I didn't believe it to begin with)
The fastest way to travel in a Tesla is fast. Yes, I'm talking 75+ mph. Sure that's a duh, but remember that your range decreases dramatically at 75 mph.
AND to stop frequently, charging between as low as possible and about 50%
I just did a quick search for a charging graph and
Look at these closely. Notice that at a 250kW Supercharger, you are charging full speed only to about 30%.
At 250kW, you are adding at a rate of over 1,000 miles range per hour.
At 125kW, you are adding at a rate of about 500 miles range per hour.
At 50kW, you are adding at 200 mph.
A little over 10 minutes to get to 50% and 40 minutes to get to 100%
