Synthetic and DOT 3/4 brake fluid is not exclusive. You can have both - the benefits of synthetic DOT4 fluid is high resistance to overheating and resulting brake fade.
You are probably thinking of DOT5 brake fluid. DOT5 brake fluid is silicone based and does NOT absorb water. But don't go thinking that this solves the brake change interval problem.
Because DOT5 does not absorb fluid, instead what happens is that the water that gets in forms bubbles in the system, creating localized areas where high rates of corrosion can occur - or if this water is close to the brake calipers, very easily boiled fluid.
So if anything, regular flushes of DOT5 fluid is even more important than DOT4.
