Hey guys,
I’m a new member just joined to say thank you to everyone who contributed in the article. I was able to fix my passenger side door handle on my 14 S85. Works fine now used all existing micro switch ripped off the back of it and used hot glue to make a seal around it and soldered the wire that fell off.
However some minor issues which popped up since:
- I couldn’t get the top door handle bolt on even with the window trim off so I just left it out.
- I accidentally did something that has left my window loose and it isn’t aligning properly when I close the door. The window going up when the door was closed ended up peeling some of the black rubber insulation and it doesn’t go up all the way unless the door is open.{Main issue} I can basically move the whole window up from the corner so when the door closes it over laps on to glass instead of sitting in the rubber.
Sorry if it’s confusing not sure how to explain it any advice if someone knows which bolt is tied with the window adjustment would be great
Looks like you loosened the bolt that positions the glass in place, seems like your window is too far back in your pic. It needs to be positioned correctly and tightened. There is a video for adjusting the glass. I'll see if I can post some pics this week about the windows since I have the parts to get some good pictures now.
