If it were me, I would redo the ground connection properly to ensure there is good contact. However, I expect you'd find many outlets done in a similar fashion.
The color of the wiring is obviously not a fire hazard and won't impact the use of the outlet. The lack of white for neutral and not differentiating the two phases is an inspection issue and a risk for anyone dealing with that wiring in the future. But if no inspection, then it is up to you if you want to address with the electrician. Not sure how long the wire run is from the photos shared.
The conduit connected to the outlet box appears metallic and not cleanly cut leaving a potentially sharp edge. Can't see the whole install to comment on anything else.
From what I have read on here, the quality of the outlet is important. Not sure if you got a 'commercial grade' outlet or not, but some of the cheaper ones are prone to fail at higher amperage or with continued plugging in and out.
