Electroman
I will take double panes and increased insulation, over dimming mirrors and USB in glovebox.
From someone who works at the Fremont plant.
Incremental improvements. I have the double pane and the improved insulation, but not the mirrors or the USB. 6966X
I just swapped from 19"s into 18"s for my winter set and it noticeably softens the ride. We have bad roads leading into where we live and I wanted more sidewall, this really helps. PSI was set at 42.
I went with Tesla Aero wheels from the Model 3 because I plan to still use the aero covers to maximize range on road trips. Also cost was lower ($2200 for the full set including TPMS sensors and aero covers) compared with most other options I've looked at.
I went with 235/55/18 tire size, 104T XL rated (General Altimax Arctic 12 based on good reviews on TireRack). The tire is narrower than stock by 20mm and outer diameter is just a fraction of percent larger. Perhaps giving up some of the performance edge but I'm OK with that for my winter set. Car still feels crazy fast with the new set and I like having the softer rubber as the temperature drops. My Model Y VIN is 60xx.
Anyone have a pic of the Y and the aero wheels without covers?
Is there a thread going about using 18s on a Y? I'm interested.
Any word on heated steering wheels or air suspension?
Very nice. Thanks!Here is mine, I don't think black is the standard color, I got these from Detroit Wheel and Tire:
Yes, it has been mentioned in a few threads, here is the one with the most info and where I first saw someone succesfully using the Aero 18"s including pics with the covers:
18" Aero wheels and Model Y load limits
I am bringing back this thread because I have a question about the 18" rims. I have 18" rims with Blizzaks and Tesla TPMS sensors on the way from Tire Rack. They confirmed that they will fit my Y. The question I have is how to configure the wheels for the car in the in car menu. The dropdown menu does not mention 18" wheels. I know that tire rack does a great job at keeping the total diameter the same so I am wondering if it even matters? I apologize if this has been covered before, but I searched and couldn't find these specifics.
Thanks!
Pat
Probably one of the biggest things that does change when changing the wheel is the tire pressure warning range. But things like traction control and regen characteristics might change and are compensated for too.
And different size wheels get different load range specs. Load range specs go up as rim size goes down. Probably because of more stress on sidewalks. Which is also related to recommended pressure. So how do you or tirerack know the correct load range and pressure to use for an 18”. Let alone tell the car what you’ve done. And why didn’t Tesla even offer an 18”, when they already had them.
For that reason, I wouldn’t put any non OEM tire size or rim on any car let alone a Tesla. I personally won’t even go with non OEM wheels.
No one but the programmers can tell you exactly what that setting does. And I’m sure you’ll get a wide range of answers from Tesla if you asked them.
My question is specifically to those who've put 18's on a Model Y, is there any configuration required? I do appreciate your response.
Pat
I am not sure if I understood when you stated "The GAWR also matters of course, but the axles all have the same load rating on the Y."Load range specs do not go up as rim size goes down. The 21s are rated for a higher load than the 20s. Regardless, rim size has zero to do with load capacity. The load rating of both the wheel and the tire are what determine load rating. The GAWR also matters of course, but the axles all have the same load rating on the Y. Also, Tesla does not have an 18" wheel for the Y. The Model 3 wheels have too low a load rating to be used safely with the Y.
The stock 19" tires on the Y are load rated for 900 kg. (104) As long as your wheels are rated for 900 kg+ and your tires are load range 104 or higher you're good to go. the next things to consider are center bore size, bolt pattern, offset, will the brakes clear, and will the mounting flange of the wheel match the car. Martian makes 18" wheels which fit, so other wheel makers probably do as well.
I am looking at the 2020 Model Y Owner's Manual, page 189. There is a table of vehicle weights:
Model Y Gross Axle Weight Rating (GAWR)
19" wheels Front/Rear GAWR: 3607/3607 lbs
20" wheels, Front/Rear GAWR: 3307/3307 lbs
21" wheels, Front/Rear GAWR: 3005/3505 lbs
I expect Michelin to market MXM4 in the MY's size and load ratings.Right and
19” has a 104 Load Rating XL
20” has a 101 Load Rating XL
21” has a 98 Load Rating XL
I think it has to do with a taller side wall needs a stronger tire for the same load.
I’m all for smaller rims for winter. But I don’t go beyond the standard OEM wheels and tire sizes so that I’m confident I get the correct tire specs. This isn’t a Corolla.
BTW, I checked TireRack for alternative tires on Model Y and they do list an 18” tire (245/55R15 103V) with a 103 load rating (less than the 19”). And not tagged as XL either. It should be more like 107 XL in my opinion. Turns out they don’t appear to make an XL in that size. I think it’s structurally not possible with that aspect ratio and size.
I’m sure the car will be fine. But if you ever had a bad accident (unrelated to tires or unrelated to load rating of a tire) I always worry about my liability (what if someone was hurt due to a blow out), Tesla’s liability (something was wrong with the car I might get a denial because I ran tires not officially supported), or insurance might claim fowl for not running OEM spec tires. Chances of that are extremely low. But I figure why risk it?
In the Performance Model Y with the 21" wheel size the front tires (255/35R21) have a load index of 98 XL; the rear tires are wider (275/35R21) and have a load index of 103.Right and
I had not seen the optional 18" wheels and tires for the Long Range Model Y. This is just WAG but what if the 18" tires 245/55R18 (Load Index of 103, not XL) are intended for the Standard Range Model Y (weighs about 500 lbs less than the Long Range and the Performance Model Y.) Time will tell.
