Exactly what I did on my recent trip to Fremont. I also had the 'calculating...' problem.
I occasionally had that problem, but couldn't nail down why. The moment I started driving, it cleared up for me.
My own experience suggests that the routing is done to minimise energy rather than to optimise time. Often, they're the same or similar.Last Saturday I was in Paris (about 90 miles from home) with 160+ miles of rated range left. Selecting home as my destination, it routed to the Ardmore SC 135 miles away (and another 100 miles from home). After removing all charging stops, it still didn't route using the shortest way.
Band-aid for what problem and what clamor are you referring to?Seems that the "program" wants you to always start with a "full tank" no matter what it takes to get you to "fill up". If it would simply give us a chance to delete the unnecessary supercharger on the listing and would re-figure the route again, it would solve our problem.
I am guessing that Mr. Musk needed a "band-aid" for the problem and this was thrown together quickly in response to the clamor.... Hopefully they are working on it and perfecting it for a future release.
73
AK4IJ
The system's logic is pretty simple. If it projects that you will arrive at your destination with less than 20% SOC or the next (distance-wise) supercharger, it will send you off to another charger that would let you do that.
Mknox,
You said that you "manually deleted the Toronto Supercharger"... that's exactly what I have been trying to find out how to do (Removing one or more without deleting ALL of them). How did you do that?
One thing I haven't been able to figure out is how to get it to show my entire route in the first place. If I, for instance, plan a 500 mile trip, it will only route me to the first charging stop and won't show me any more of my trip (unless I "Delete all Charging Stops").
I use it on long trips to see an overview of my entire route, but then I cancel the navigation and pick the next Supercharger and navigate leg by leg. The system just doesn't work. Always adds unnecessary stops and each time you get out of the car and back in, the navigation is stuck and only shows 'calculating...'. How good is a navigation system that adds charging stops but then locks up each time you do a stop?
The summary is shown on the screen with the "remove all charging stops" button, at least it provides a basic read-out of total miles and time (not sure if it includes charging time or not). Is that what you're talking about, or something different?
You have to tap the button that says "Trip" or "Route" or something like that (not in the car now), then a screen will open with the option of "Delete all Charging Stops". It seems to be an all-or-nothing proposition in that you can't selectively delete single stations.
Tap the lowest bar of the "next leg" window (where it shows miles & time). That will put the "Trip Path" icon (not sure if that's the name -- it looks like a curvy road) on the bottom of the window -- press it that to display the trip overview (which sometimes isn't highlighted very well, depending on the zoom level).
Or... I misunderstood your question :smile:
I'll try that again, but I thought it still was only showing the first trip leg and not the entire route. Thanks.
