When we had the previous poll 17 people raised their hand, which we reckon could be multiplied by ten due to the numbers active on this site vs sales.
I'm very excited to report that I finally have a prototype for testing! I'm extremely busy at work this week but this weekend I should be able to wire up a couple more. I'd like to send these to a couple of you who can test them while I finish CE certification and gear up to produce a few more. All components are rated for at least 75A. All I did was the adapter Mennekes to Roadster connecter. You will have to get your own cable to go from the charge station to the adapter. If you want I can supply that too but the cable is fairly ubiquitous.
Send me a PM if you're interested in getting one for testing. The price is going to be around 750 USD plus shipping (approx 550EUR, 500GBP + shipping). You don't have to pay until you get it and confirm it works. The prototypes are poorly finished so if you get one of these you can exchange it later for a production version. So far I tested the Roadster plug at 70A by attaching it to the end of my HPC cable. Then I screwed one end to a J-1772 plug and tested that at 32 A on a Chargepoint station. After a few minutes it tripped the GFCI but I called the company who said it was doing the same thing with every car that plugged in.
If I'm wasting my time and you no longer need this, let me know. Tesla may have already released theirs? I'm not really making any money - just trying to help the greater EV community so let me know the interest level.
the adapter Mennekes to Roadster connecter. So far I tested the Roadster plug at 70A by attaching it to the end of my HPC cable..
I was going to powder coat the outside sleeves but then I kinda liked the brushed aluminum look...photos?
I started with the plug in the car and said "what is the best way to connect to this?" I did not reverse engineer Tesla's version. In the end, my connecter had some similarities and some differences. Functions just as well. It's water tight. Not quite as complicated. All parts rated for 80 Amps.How could you manage to get the Teslamotors propriatary Roadster Connecter and wiring for 70A
Keep in mind it's a prototype. A production version (if I do it) will be an inch or two shorter overall.
Let me know what you think I should do to improve it.
Sweet! Given the form factors, I always envisioned a Tesla to J1772 adapter as a barrel adapter rather than the long pigtail they supplied. Cool to seen an implementation with Mennekes. So basically you've made your own version of the Tesla connector without the thumb slide switch.
My main concern would be the lever arm that long adapter puts on the Roadster inlet cup. Sounds like you're already working on making the adapter shorter. How long is it now and how short do you think you can make the final version?
Since you already can make your own Tesla compatible connector, why not go ahead and make the full Mennekes cable. I'd also think a few folks would be interested in your Tesla compatible connector alone since they seem so hard to come by.
The problems I see are that it would be limited to 30A, which would satisfy most public charge stations currently, but not the 63A stations on the horizon, and it would require a separate "commando portable EVSE" as you call it to fake the communication to the car and the real EVSE. That might work in most cases, but not as reliable or functional as putting the pilot straight through. You would have to modify the MC240 or UMC to gain access to the pilot. It wouldn't be just plug n play....
The next step is putting a Mennekes socket on the outlet of the MC240. Then I will have both a Mennekes to
Tesla cable, and also a 30A commando to Mennekes portable EVSE. Btw, the latter of course could as easily charge a LEAF or iMiEV using a Mennekes to J cable.
As for making the Roadster adapter available by itself, I'd like to do that sometime soon. I also want to sell J-1772 adapters. i don't know if there's enough demand to make it worth it. There's not much money to be made but it's fun and I like helping out other owners...
Call me back when they have one rated for 70A. In the mean time, I built my own.Fantastic that you have managed to replicate the Roadster connector. It might be a cheap way to a variable portable charger if combined with this: https://www.homecharging.spx.com/Portal/pdf/SS10-283_REVB.pdf
I meant to point out then, but was recently reminded, that that kind of adapter on the vehicle side is "forbidden" in Europe. Might not matter for your purposes, but makes me wonder what kind of solution Tesla will provide.Since you already can make your own Tesla compatible connector, why not go ahead and make the full Mennekes cable. I'd also think a few folks would be interested in your Tesla compatible connector alone since they seem so hard to come by.
I don't think it's too hard to find the M to M cable. A lot of people already have one.
(scratching head) Doug where did you see this regulation? I haven't run across anything that suggests this kind of adapter on the vehicle is not allowed. I'm not doubting it... Is it in the IEC?I meant to point out then, but was recently reminded, that that kind of adapter on the vehicle side is "forbidden" in Europe. Might not matter for your purposes, but makes me wonder what kind of solution Tesla will provide.
