The obvious place is to hang out at Wikipedia's entry on NEMA connectors. It's my go-to place. Going along those lines, here we are:I asked my mom. You are right its probably not 220v. Its probably 120. Anyhow a guy is coming next week to install a brand new outlet. So I guess we will see if we can make room from the breaker box or not.
The only way to go, in my opinion. I know a great electrician with good rates. I live in Southwest Suburbs.We are getting the wall charger.
Yes I noticed that too these past few days. Went to whole foods twice. They have super chargers. But it was charging slowly because today was about 32 degrees according to weather dot com. It said charging slowly or something like that. But when I use the right button on the streering wheel and say navigate super charger it preconditions. My brother in law told me. But their 2018 model 3 does not have a heat pump. So it wont work here. Or do all teslas precondition? It was only giving about 51 to 61 kwh at the super charger.No problem. Modern EVs, including all currently sold Teslas, have a heat pump to warm up the battery. It helps with range and performance. Especially if you pre-condition before heading out. We only have electric cars on our household and it isn’t a problem at all
There's a whole little list of What To Do In Cold Weather that Tesla puts out.Yes I noticed that too these past few days. Went to whole foods twice. They have super chargers. But it was charging slowly because today was about 32 degrees according to weather dot com. It said charging slowly or something like that. But when I use the right button on the streering wheel and say navigate super charger it preconditions. My brother in law told me. But their 2018 model 3 does not have a heat pump. So it wont work here. Or do all teslas precondition? It was only giving about 51 to 61 kwh at the super charger.
And the wall charger gives how many miles per hour? Is it slower than outside super charging? But faster than 120v?
Isn’t that Willow Festival?View attachment 1004893
These were from google not my images about 3 years ago. But still looks the same.
Since this is general contracting work, the usual rule of thumb is to get three estimates. This is one guy; got another (legit, licensed) two showing up in the near future?The guy came today for estimate and he said the breaker box needs to be redone and it will be about 4 thousand. Or he has a device (I forget what its called) goes in the breaker box and limits the house to 80 percent when other things are running like laundry.
Get a few more “guys” over for estimates/ second opinionsThe guy came today for estimate and he said the breaker box needs to be redone and it will be about 4 thousand. Or he has a device (I forget what its called) goes in the breaker box and limits the house to 80 percent when other things are running like laundry.
This is a great, very informative post. Thank you very much for posting. I am surprised you don’t have more “likes” not that you should care.The obvious place is to hang out at Wikipedia's entry on NEMA connectors. It's my go-to place. Going along those lines, here we are:
Note that the connectors aren't to scale; that is, a NEMA14-50 is physically larger in diameter than a NEMA5-15, and so on.
The Tesla Mobile Connector (Has a NASC/Tesla connector at one end, a longish cable, a thick part with electronics, and a socket on the thick part) has multiple adapters available that will plug into a number (but not all) of the NEMA connectors. Back in the day when Superchargers were (relatively speaking) few and far between Tesla would throw a TMC into the trunk of every car, along with adapters for a NEMA5-15 (standard 120 VAC, 15A wall socket) and a NEMA14-50, a 240 VAC often found in RV parks and the like. Maximum current on a TMC is, no matter what one plugs it into, is 32A. Taking a quick look over at Tesla's web site shows the following available adapters:
The second pair of digits (15, 20, 30, etc.) tells you the max current on such a socket and the required circuit rating that said socket is connected to. (That is: A 30A socket must be connected to wires rated for 30A or greater, and must be connected to a breaker rated at 30A. No ifs, buts, or maybes: This is house-burning-down stuff.)
- NEMA5-15
- NEMA5-20
- NEMA6-15
- NEMA10-30
- NEMA14-30
- NEMA14-50
- NEMA6-50
And, the usual caveat: The National Electric Code (NEC) says that when there's a constant, heavy load (that's a Tesla) the maximum load is 80% of the circuit rating. So, if one is using a NEMA6-15, 80% of 15A is 12A, and that's what the car/TMC will draw when plugged into such an outlet.
So, back to your place. That socket, with the little right-angle bit on it in the wide blade, is clearly a NEMA5-20. 80% of 20A is 16A; so the maximum power you'll get out of that socket with a Tesla is 120VAC * 16A = 1920W, which as stated at that Tesla site I linked above, will give you around 4 or 5 miles of charge per hour... if it's not too cold out.
A NEMA14-50 wired to a 50A breaker will run up against the limit built into the TMC of 32A; so you'll get 240 VAC * 32A = 7680W, and about 30 miles of charge per hour.
If you get a Wall Connector that is wired to a 60A circuit (that means adding a 240 VAC 60A breaker to your breaker box, running the wire to your garage, and hard-wiring it to the Tesla (or somebody else's) Wall Connector, you'll get the max power you can stuff into a Tesla: 240 VAC * 48A = 11,520W, which works out to be about 48 miles of charge per hour.
And there you are.
Just thinking, 32 Amps continuous (using 40 amps socket) at 240 volts (such as dryer plug, etc.) is 7.68 kWh. Which is about 28 miles of range per hour of charge on my MYP I am currently averaging. Plenty
I don’t think its 0.06872c, but $0.06872.Also we called comed today. We have no off peak hours. Same rate all the time. Unless we switch. So we currently pay 0.06872c pkwh. So how much then to fill up my tesla model y with 74kw battery?
Wowzers. You pay $0.06872/kW-hr? That's extraordinarily low. Must be next to a hydroelectric plant or something.Also we called comed today. We have no off peak hours. Same rate all the time. Unless we switch. So we currently pay 0.06872c pkwh. So how much then to fill up my tesla model y with 74kw battery?
