Dropbox - UPDATE_C0000A9.EBL
Dropbox - UPDATE_C0000B9.EBL
Dropbox - UPDATE_C0000C9.EBL
Dropbox - UPDATE_C0000D9.EBL
A 75% TPS Threshold for logging
B 50%
C 25%
D is switch triggered logging
Changes for version 9
Data file increased from 1 meg to 3 megs. I was mistaken on erasure time. I was already doing a complete chip erase so the larger data file does not increase erasure time.
Added switch on for logging. As usual, switch away from LED side of plastic case parting line is "Off". Plug the logger in with the switch in the down or off position. You will see the RGB LED Post sequence followed by one or two red blinks indicating the number of motors in the car. Turn the switch on to log and off to stop. When switched off, the logger's LED will go from Green to Red while it waits for a battery health temperature message (up to 3 seconds) so that it can write the end of log SoC, BatT and BatOdO values. The logger is available for the next log set after the Red LED extinguishes.
This version is not as throughly tested as the last so let me know if you find anything.
Lastly, one person asked for a logger and it fell completely off my radar. Sorry and I will remedy that today.
- - - Updated - - -
KB,
Care to take a stab at overlaying P85DL and P90DL torques, current and battery voltage? My initial take was that the only advantage the P90DL had was slightly less voltage droop under load. I suspect the torques and current profiles will overlay perfectly on compatible good traction launches while the 90's battery V will be slightly better.
B 50%
C 25%
- - - Updated - - -
KB,
