Ok, I'm so wishing I had a couple of hours of my life back currently - this was real boring. 1.5 mile section of almost level freeway, loop back round, same 1.5 mile section of freeway, loop back round... and 6 more times... with the climate control off... then come back and plot them
Here's range mode on / off at 70mph: rest are pretty darn similar. Available as MikeBur 02-25-16-RangeModeTests.xlsx on the google drive share.
Only interesting aspect was the interesting pattern on the power data.
Hope this helps, Mike
- - - Updated - - -
Hi @KennyBobby,
I tried 3 times to get some level of traction slip using slip start - no luck. These tires are just too sticky, even at >90% SoC. The 3 attempts I did are in the RangeModeTests xlsx just mentioned above if you want to check out the craziness. wk has a way to turn off traction control on the pXXDs that would be more like what you want, though I believe he likes his tires
