Yeah I doubt that the 6-20p to 5-20R adapter is bad there are no electronics involved just copper to copper...
I haven't tried the adapter on any 5-20R outlets, because I have none in the house
The UMC light is green when breaker is on with my convoluted 6-20 setup, and it's not plugged into the car. As soon as I plug the car in the voltage on the charging screen is cycling between 1 and 0 briefly at 16 Amps but then the breaker trips and it never starts charging. After the breaker trips it appears that the Amperage setting in the car gets reset to 48a (so I was wrong about the car dialing it up while charging it appears)
The 14-50 charging was working fine at the store although they used their own UMC.
I don't have a 14-50R at the house unfortunately- need a service upgrade (only 100amp service on the main panel - old house) and a new line to get it which was estimated at $5000 by a friendly electrician, hence the 6-20 finagling I'm clearly.messing up on.
The weird thing is that the pool pump on the same circuit turns on fine without tripping the breaker. But the UMC/car combo trips it every time.
That's very strange. Someone just returned my similar 6-20 to 5-20 after using it on a trip and said it worked just fine. Have you ever used your UMC 5-20 adapter by itself in a 120V 20A outlet? I wonder if that is defective. Also has your car set the amps wrong when using a 14-50?
