dhrivnak
I too am getting the BSM: Isolation Fault and the car will not charge. It is damp and rainy. Will let Tesla service know but am worried that I am out of warranty now :scared:
Allow the Roadster to dry out, the issue will go away and you'll be able to charge then. Just need patience now.
Correct. I went on a drive to heat things up and I was able to charge. Is anyone aware of a fix?
Just went out to try again and can now add #283 to that list of faults.
I've just had this same issue. Tried to trigger a charge remotely and got #287: BSM: Isolation fault before charge / Powertrain Problem Service Required. Came back to the car and tried again with both cables with the same result and a red ring around the charge port.
I drove the car out of the garage and over to my other EVSE with the same result. Then when driving back to the garage I got several #286 BSM: Isolation fault while contactors closed.
All I can think of reading this thread is that it might be due to me washing the car lightly with a hosepipe on Sunday to remove some bird crap from the roof and mud that had got up under the arches.
The car has been garaged since and I should add it's been in storage mode and done the daily storage charge since Sunday without any errors AFAIK.
I've only got 30 miles in the tank so I'm scared to go driving it an using them up if I can't charge. The PITA is the car was due a service and is going in on 9th Jan, but now I can't charge to get it there.
I think 287 was the error code I was getting. It only showed up when initiating a range charge, and simply closing the charge port door and reopening it cleared the error and a second attempt to charge would usually work. Tesla ended up swapping out the whole battery.I have also apparently fallen victim to a flavour of this problem, on a 2.0 Roadster. I get the fault 287 error and red LED ring right after the contractors close. I have only gotten it when a charge has started after the car has been sitting for days or weeks in the garage (our Roadster is no longer a daily driver, especially in the winter). It has happened now three times. After the first time, Tesla came over and replaced that HV controller under the hood, which was not showing its pilot light. That did not fix it. They then took the car into the shop, with me driving it part of the way and them trailering it the last stretch to preserve the SOC (it had been in Storage Mode). After that drive, it immediately charged for them in the shop. They talked to Roadster expert engineers at HQ, but the failure pattern documented in this thread did not come up, apparently.
It has now happened two more times, but each time, just driving the car for as little as 10 minutes corrects it. I have never seen faults while driving, only while beginning a charge. Usually I discover the problem when returning from being away (without the car) and see the fault pop-up on the VDS. So it is initially happening during an SOC maintenance charge while parked plugged it. Our garage is near-100% humidity in the winter here in BC, with the cars often coming in out of the rain carrying a lot of water. I will see about improving ventilation and perhaps get a dehumidifier.
I will now bring this thread to my service manager's attention and see what they want to do. Thanks to all above for documenting this failure pattern, and to FANGO for directing me to this thread, which I had missed.
