PLEASE HELP, MY CAR MAY SOON BE BRICKED! I have this problem with a 1.5. The lowest brick is 2.5 volts so I guess the car will be bricked if I don't do something smart.
It is -5 degrees C outside.
I took the service disconnect and got the battery heated to 8 degrees C (lowest brick), but it seemed like the power was taken from the battery since the cell voltage of lowest brick dropped from 3.1 V to 2.5 V. The charging amperage showed 0 during heating which it normally don't do.
What can I do?
I tried putting a heater under the dash as it was metioned in this thread. It did not help (I used the service disconnect to reset the car but the same BMS Contractor Power Failure).
Should I try to open the PEM and heat the PEM?
I will try to heat the garage, it is partially open so I will need to find a way to close it.
