Hell of a detailed answer, thank you so much for the detailed write up.As a lawyer I always love sourcing and the root information so I can review. I will definitely read into what you provided.I have seen data online about percentage of swapped batteries on different EV’s including Tesla. But the absolute main part in early battery life have to be other failures from hardware like the BMS or mouist intrusion etc.
I think we see a number of batteries getting old and causing fault codes right now on the forum on model S out of warranty that probably is degradation related.
Initially, for the first five or eight years or so, the calendar aging/ age is the (very) dominating factor in degradation.
High SOC wear more and higher temperature wear more.
The cycles counted in throughput is usually referes as Full Cylcles Equivalent (FCE) in the research. It is more to it than the throughput or FCE.
Larger cycles wear more.
Cycles positioned at high SOC wear more.
Small cycles at low SOC generally gives the best throughput or number of FCE’s.
Low SOC in the regime where we normalky can use the car (0% displayed and up) do not cause increased wear.
It is the high SOC part of a cycle that is causing increased wear.
The research with Panasonic 18650 NCA cells show us that they can do about 700 cycles from 100-0% (4.20V - 2.5V/cell) with the current or C-load comparable to a highway driven car before the cells lost 25% capacity.
Thats 700 cycles from 100% displayed until the car stops and can not drive.
This would be about 700x400km = 280K km on the average model S, or 175K miles.
This test is of course performed in a short timeline, would take about 7-9 months to complrte the test so not much calendar aging.
If the charge level was reduced to about 90% (4.1V) but still down to 0%, we get 850 FCE cycles (so about 950 single cycles) and if reduced to 80% we get about 1000 FCE (so about 1250 single cycles)
This is consistent with more or less all research. There is a lot of research showing the same thing.
This picture shows same type of cells cycled between 0% and different SOC,
3.7V = about 50%
3.8V = about 60%
3.9V = about 70%
4.0V = about 80%
4.1V = about 90%
4.2V = 100%
We can see that the low part of the cycle is not the bad part.
The lower the cycle is positioned, the lower the wear.
Pictures from This report, a good read covering the most parts and aspects.
That report is in line with litterally hundred other reports, so not just one of a kind.
Is there a way Tesla, when they have my vehicle for the MCU2 upgrade, would be able to tell me what my level of degradation is?
