I hope AWD is less than $5kUSD for a $35K base model sedan. I haven't looked at many competitors, but the difference between the 2016 BMW 340i and 340i xDrive is $2600CAD.
It might be a bit less since Tesla will be making more drive units but keep in mind that Tesla accomplishes AWD by adding a 2nd drive motor/inverter and gearbox. Getting the cost of an entire drive unit down to $4k would be a major accomplishment.
... and the brake pedal still engages all 4 wheels....
FWD is preferable to RWD in snowy weather. Not for everyone, but for most people most of the time. It's not weight distribution. It's because understeer is easier for most people to control. Also steerable drive wheels provide the ability to vector thrust in the direction you want to go.
The Model 3 will be half the cost of the Model S but I doubt the options will be. I think the best we could hope for is a D for an additional $4500.I chose AWD, since I'm planning to go for a PxxD Model 3. I think the $5K price mentioned may be a bit high. That is what it goes for on the Model S. Since they seem to be targeting roughly half the price of Model S for the base price, I will blithely assume it is similar for options. My guess is $3K for dual motor and another $10K for performance.
Yes, AWD does help a lot when the car is traction limited, since each wheel can provide a little bit of traction without slipping. But this is also true in cornering, so turning is improved in slick conditions with AWD. You are correct that AWD doesn't help with stopping except that regen slowing is improved if all four wheels are helping, which is different from ICE AWD and braking....AWD only matters when you are trying to accelerate and are traction limited, such as when you have a ridiculous amount of power like the P90D, or when its snowy. Course it doesn't help you stop or turn any better in the snow, so is benefits in the snow are way overblown.
Good point on the torque steer. I forgot about that. Some of the high performance FWD (like the Mazdaspeed3, Focus ST) use electronic aids to address this (Mazdaspeed3 with engine throttling, Focus ST with power steering adjustments) or some more expensive suspension (like revoknuckle in Focus RS). Much simpler to just go with RWD, plus with the weight balance of an EV, straight-line performance will be better.FWD is IMO totally impossible if the M3 has anywhere near the torque to mass ratio of the Model S.
FWD made sense in low torque front heavy ICE cars, especially before the age of electronic stability control. They were space efficient and as many pointed out, cheaper to make due to the lack of external diff housing and transfer shaft. An FWD EV would probably be marginally more expensive then an RWD EV since you need better CV joints for the steered wheels. And you wouldn't gain any interior space or traction.
