Not sure if anyone experienced this. Getting in and out of the Model S in a tight garage, when you can only open the driver's door partially has its challenges. Since the vehicle sits low, exiting the car even with easy entry, can be difficult as you try to weave your legs from a stretched-out seating position through the door opening and stand up from a crouched height. I'm not mobility challenged, but I suspect many of us older clients may have witnessed this situation, like getting out of a low chair. A clever solution is to simply auto-raise the suspension at your home garage, if your MS has this built in feature. This allows you to exit the vehicle much easier from a raised position. So, it's not just for high curbs, steep inclines, or rough pavement for the auto raise settings. Just wanted to share this with the TMC community; your comments would be appreciated.
