I tried changing the wheels from my 19" to 21" on 2022.28.2 and it did NOT do the full 5 minute reboot with clicky noise things. It did a very quick flash of the screen and then showed the updated wheels. I think they changed something recently that the car doesn't do the full reset like it used to. I haven't tried changing the language trick yet though.I know you've been around here for a while, so probably you know that you can trigger a deeper (weirder?) reboot by changing the wheels in the interface, or alternatively, switching to another language. I've read it cures weird software related issues for others. Already tried?
Air Suspension. It wasn't 5 minutes, maybe 2-3? But it felt like eternity when the screen is all black and you are praying that the car comes back alive. Definitely longer than the normal 2 button reset though.That's a long reboot. Your car is coil or air?
I hope its a typo n u meant 035 not 053...I can get the BMS_W053 error is I let my car preheat for about 15 minutes (remotely turn on climate control via app). When I eventually make it into the car it will give
me all these scary errors and then they all disappear as soon as I start moving.
I get that DUs are more common but isolation error could happen due to other issues like Battery heater or AC compressor...That's an isolation fault in one of the motors. There's a drive unit replacement in your near future.
Source: Been there, done that, was 5 hours away from home when it happened.
I updated to 2022.36.6 as well. I took a long trip from 99% and got home at 15%. I unloaded the car and waited about 45 minutes and then looked and it was at 9%. I started charging and set the limit to 92% and when I checked it when it was done it was at 98%. Definitely weird things going on.I had a weird thing today. I got 2022.36.6 and after upgrading the car charged to 94% even though it was set to 90%. I drove the car down to 90% and the car said charging complete when I plugged it back in.
OK. Tesla closed the ticket I had opened to resolve the issue with no software update being received. So, I decided to do:
- Attempts to do the "Wheel Configuration" did not change my wheels at all no matter what wheel I selected (maybe it does not work for the older cars?), but the reboots occurred and a few knocking sounds could be heard during the reboots. BTW, the reboots weren't any longer than the two-thumbs on scroll wheels reboots.
- Attempts to do the Software\"Service Mode" to reinstall the existing software also failed with a message saying "Failed to request software reinstall: another update is in progress. Please try again".
I've left the car in Service Mode to see if any updates would eventually show up. So far, after 5 hours, no luck even with a very strong WiFi connection.
My car has done similar things for awhile so I wouldn't say it's related just to 36.6. My car often stops charging before my set 90% around 87-90% and will display 'complete' and there's been times where its been at 92% when it was set to 90.I had a weird thing today. I got 2022.36.6 and after upgrading the car charged to 94% even though it was set to 90%. I drove the car down to 90% and the car said charging complete when I plugged it back in.
Mine has done 1-2% and maybe even 3% at most previously (Set to 90% and find the car at 92% the next morning). I could see it changing a few percent with the battery warming up after a long charging session and then cooling down but my 6% change seemed a bit excessive especially after only 45 minutes.My car has done similar things for awhile so I wouldn't say it's related just to 36.6. My car often stops charging before my set 90% around 87-90% and will display 'complete' and there's been times where its been at 92% when it was set to 90.
Got a similar response, saw the remaining charging time jump up and down initially and then stabilizing again.I updated to 2022.36.6 as well. I took a long trip from 99% and got home at 15%. I unloaded the car and waited about 45 minutes and then looked and it was at 9%. I started charging and set the limit to 92% and when I checked it when it was done it was at 98%. Definitely weird things going on.
I kind of thought that my battery might be starting to starting to die (It's still under warranty till 3/2024) but with your data point maybe the 2022.36.6 BMS is going a bit wonky on these older packs. I dont think the pack could have cooled down that much in 45 minutes sitting in my garage for a 6% loss or why it overshot my charge limit by about the same amount.
I have noticed this on the last few updates on both the old '15, now departed, and the new '22.Mine has done 1-2% and maybe even 3% at most previously (Set to 90% and find the car at 92% the next morning). I could see it changing a few percent with the battery warming up after a long charging session and then cooling down but my 6% change seemed a bit excessive especially after only 45 minutes.
I dont have have the health test button on my 2016 S90D in the service menu. Additionally i just got 2022.40.4 with the only change log item being "minor bug fixes and improvements".I have noticed this on the last few updates on both the old '15, now departed, and the new '22.
Might it be the battery improvemrnts mentioned in the update notes, the ones that take pack temp and weather conditions into account?
Of interest perhaps, is that you can now on 2022.36.6 access battery health data in the service mode, at least in the new cars:
same, read all the release notes online and was disappointed to see that was all the legacy cars got when it installed.I dont have have the health test button on my 2016 S90D in the service menu. Additionally i just got 2022.40.4 with the only change log item being "minor bug fixes and improvements".
I honestly don't know what you are referring to I hope I don't get whatever this is; I like mine just the way it is thank you very much. But it doesn't surprise me they are putting more "big brother" options on their cars, as there are more and more inexperienced drivers buying these Teslas. Always some idiot ruining it for everyone else.Has anyone with AP1 seen this ‘blended regen’ braking installed on their car yet? I think I read somewhere that all cars from AP 1 and up were capable, I just haven’t seen it on mine yet. 2022.40.4 is staged on the car with 2022.36.6 installed - I’m not a big fan of these bug fix releases with no proper notes however
Cheers
