So you can't initiate it from the phone? C'est dommage.I got the message in my phone just as I was getting ready for bed, so I popped out to the garage, pressed the button, and went to bed.
Hey Doug. Since you are the proud owner of 6.1 and I believe you experienced the Canadian 3G problem is it fixed? I lose 3G most drives even with 'always connected' (or something like that) selected.
I'm not convinced my iphone app will notify me of the firmware upgrade.
I don't have much in the way of 3G problems since they replaced my intermittent antenna cable, but I did have issues if the car went to sleep. I haven't tried re-enabling Sleep Mode since the update. I will do that.
- - - Updated - - -
Do you have that notification turned on? You have to enable it in the app.
Just got mine too, updating now.I just got the magic notification on my iPhone - down to the garage to start the upgrade. I had noticed earlier on my Access Point software that the Tesla had downloaded 200MB and figured it must be the upgrade.
I just got some Ubiquit Unifi access points to use around my house. One of the reasons I decided to get these is that my Tesla was having trouble connecting into my LAN from the garage. These look kind of like 9" circular smoke detectors although they aren't as thick as your typical smoke detector. They are generally mounted on a ceiling or wall and use PoE for power so there is only one wire coming into the device - each unit comes with a PoE injector so you can use that or a PoE switch. They can either connect into your LAN via ethernet cable or you can use wifi for that as well - although I am not doing that, at least not yet but I am still setting them up. I paid $100 per device including HST and shipping from Amazon.ca.@wayner: what access point software are you referring to that gave you the insight into the Tesla download? Very curious.
I gotta say, I think this is bigger than 6.0. .......Press and hold FOB trunk button and the charge port pops open - huge convenience at J1772 stations. I'm always having to go back inside to pop the darn door
I got the update yesterday over 3g since I stopped using wifi as a result of 3g connections issues in this thread: 3G connectivity issues since V6.xxx
I wonder if this update fixes it?
