NigelM
Recovering Member
AM/FM, Satelite, and Cellphone?
AM/FM and Satellite are in the back (see Flasher's post up-thread). Cellphone could be one antenna, still curious as to what the other might be.
Key fob antanna is on the inside of the door at the end of the dash.
Then what are the antennae in the mirrors useful for? I think somebody should ask a Tesla engineer.
I guess there's no chance either of these antennas are blind spot sensors?? Would be cool.
Correct, more or less. They're on the inside of the dash end-panels. Would post a photo, but on iPad at the moment.
I guess there's no chance either of these antennas are blind spot sensors?? Would be cool. Unlikely though, and they seem kind of haphazardly placed.
Here is a photo of the key fob antenna, located in the driver's side end-panel of the dash.
According to speculation on teslatap.com http://teslatap.com/undocumented/ the antennas in the mirrors are Data/3G and FM radio (maybe AM also).
Hmmm, but why two antennae in the mirror?
DonD - do you know what was connected to the white connector (black cable). It's normally not connected. There has been speculation that it's a USB diagnostic port for Tesla Techs, but the white connector is very non-standard (for USB) connection. Did it go to a laptop or something else?
My understanding is there are FM antennas in each side mirror, and one on the back glass. A diversity design, common on cars today, looks for the best signal from multiple antennas and selects one antenna with the best signal. It can switch antennas very quickly to keep the best signal. This technique was started when car makers got rid of the whip antenna (the best, but ugly), for ones built into various parts like the front or rear glass, that are not as good and/or are affected by the cars rotational position relative to the signal.
I also believe the passenger side mirror holds the AM antenna. I'm not sure there is one in the back glass or not.
In addition, the antenna amplifiers do not seem to have extra connectors that would run back through the harness to the mirrors. I suppose it could be a diversity system that used non-amplified antennas in the mirrors and amplified antennas in the rear, but that just seems like a bad design...
Thanks for the additional details. Do you know if they replaced the amplifiers or added the amplifiers that didn't exist before?
That's backwards. Higher frequencies use smaller antennas.I suppose small antenna for radio. Longer antenna for navigation. You need bigger antennas for higher frequencies.
