Thanks for testing the limits for those of us (im)patiently waiting for the update notification!
Believe me, it's my pleasure! You guys are gonna love it!
Perhaps all of the TACC and ACC discussion should be pulled into its own thread.
Ah yeah, I have no issues with Tesla service. They're always great.
I was just hoping it was something they could reset remotely or something.
- - - Updated - - -
I'll note that when the TACC was working... it was pretty awesome. Better than any ACC I've ever used in other vehicles (only used a couple of others).
I was curious as to how it would handle coming to a stop on the closest setting, and the car in front of me came to a stop, I was ready with the brake pedal, and it took the pedal from me and slowed perfectly. So, it doesn't just use regen, it will actually use the friction brakes when needed. Worked when a car in front of me slowed to make a turn also, then when the car was out of the way it just sped back up to the set speed.
The fact that it can stay engaged after full stops and such is pretty neat. Just takes a tap of the pedal or lever to continue.
I look forward to using this more...
Yes it still works.I'd love to hear how someone with this update experiences ACC when regen is limited due to cold. Does it still work?
It will be interesting to see over time how many people turn off tacc after trying it, and how the system improves with software updates rather than requiring updated hardware.
Can you turn it off? One of the most annoying limitations of the ACC on my previous Audi A8 was that it was always adaptive - there was no way to make it fall back to the non-adaptive variety. As a result of this you could also only set 5mph increments on the target speed in that car (since you never have to make fine adjustments to suit the traffic, since it's adaptive).
I do not see an off setting and never understood a reason you would want to either.
Isn't there a driver assist option you can set so car will stay within X mph of posted limit (as detected by mobileye)? My P85 doesn't have any of this driver assist stuff (of which I'm glad), but I had loaner for 2 days this week and I could swear I saw that.
ACC is brilliant when there are cars to follow.
But if you're on an empty freeway doing an 80mph cruise and you come up behind another car doing 65 then as soon as the ACC catches sight of the slower vehicle far ahead it starts slowing down, even though you know you are are obviously just going to pull out into the next lane and overtake it, and the only way to stop it from doing this is to start pulling out into the next lane comically early.
I don't believe so. When using a 1/2 second (seems to be closer to 2) pull on the cruise control stick matches your cruise set point to the current speed limit +/- your override value, eg.
Observed behavior:
In 35 zone, enable cruise control, pull cruise stick for 1/2 sec+, release. Car cruises at 42mph (my override is 7 over speed limit, and I like 42 ;-)). Car enters 25 limit, car still cruises at 42, after telling you that speed limit has changed to 25...
Result Mike quickly presses cruise stick down (all the way 3-4times), ie 42-40mph, 40-35, 35-30, then maybe 30-25 (if it's school zone, etc)
Utopic behavior (for me):
cruise override value is %of speed limit (eg 15% over), eg. 69 in 60, 40 in 35, 28 in 25 (assuming truncate), and car changes cruise control set point when moving between zones, both up and down.
Of course, my update did not complete successfully and I have Tesla service fixing next week, so maybe I'm out of sync here too?
I used TACC for about 45 miles up 280/380/101 from Palo Alto to San Francisco. Works just as advertised and my drive felt more relaxing. I feel less tired from driving compared to how I would usually. I also averaged 290kw in my P85D compared to a normal of around 340.
One word of caution is that the system still requires oversight. I was approaching the end of 280N into SF and the car in front of me pulled into the right lane. The traffic in the left lane was fully stopped but beyond the end of the curve. The car started accelerating up to 70mph and wouldn't have had enough time to stop. I've found TACC to be excellent for pure highway driving but I would advise against using it anywhere else -- just like the case would be with any cruise control.
