When you use one phase, the motor will not rotate at all, so the rotor type is irrelevant. But I guess that when you use it as an inductor for the three phase, you are in fact creating a rotating field inside the motor and the only way you can prevent the rotor to rotate is if you have a wound rotor and you disconnect the wires. In a permanent magnet rotor you have the problem of hold the rotor using the brakes, quite dangerous!! And in an induction motor there will also be a large current inducted in the wires/squirrel cage that will burn them in a short amount of time.
Anyway, I can be wrong so please tell me if you disagree
I disagree :biggrin:
They wouldn't need the inductor for the three phase end. They might need an inductor at the DC end of the rectifier for smoothing, but that will not generate a rotating field.
The point of using an inductor is that it resists current changes. Think of it as a heavy, freewheeling turbine in a water pipe. Pressure corresponds to voltage, flow rate corresponds to current. A pressure pulse in the water will speed the wheel up a bit, a pressure drop will slow it a little, but the flow will be much smoother than it would have been without the wheel. As a result, little current would be induced in the rotor, because induction is proportional to the rate of change of the magnetic field, and the magnetic field is generated by the current and thus equally stable as the current.
*Edit* And now it just struck me that they don't need any extra smoothing of the rectifier output, because this the regen circuit, which obviously must be able to smooth the current without the benefit of the use of the motor as an inductor - that's where the current is normally coming from! I don't have any idea what they would need the motor for, if anything. AC Propulsions' reductive charger would need this, because rectified single phase is much harder to smooth than three phase.
Aside: Keeping a permanent magnet rotor stationary in a rotating field will likely demagnetize it, which would be unfortunate :scared:
I think same or higher prices of charging per kWh of energy.
Price per kWh is interesting, but not all that matters. Unit cost matters a lot. You just showed us that the RWE pole is less than half the cost and can charge two vehicles. You also need to compare outdoor AC cost to outdoor DC cost.
Also, a hotel will probably not put up a whole RWE charge pole. Those are more expensive than necessary in that setting, they are built like a tank to withstand abuse out on the streets. Check out Kevin Sharpe's projects for more realistic costs.
When you arrive at a hotel for a conference, would you prefer to get an 11 kW charge point all to yourself, or park temporarily at the DC charger and then have to leave the meeting to move the car after an hour? 11 kW or certainly 22 kW is enough in this setting. The hotel would be able to serve four customers with less hassle for the same price as the DC charger.
If it's a half-day conference, then you very likely haven't driven all that far to get there, and 11 kW is enough to top your car up. If it's a full day conference, you will get a full charge even if you arrived empty.
This is the only chance for high power AC charging to be in some applications profitable.
Correct. However, each and every EV has a powerful three phase inverter, which as Renault has proved can be reused for charging at multiple single and three phase power levels at exceptionally small cost. This is the way it will be done, and that means that DC charging at less than approximately 70 kW is
dead as a dodo in all markets where you can easily get three phase power. I'm all for truly high power DC, but it needs to provide a significant extra punch above 43 kW three phase to be worth the extra cost, I'd say 75 kW as a minimum.
