Soo, the other day i got a call from work to go urgently to a site 200 miles from my home.
My car was sitting in the driveway with 30 % SoT, the plan was to charge it the next day using solar power as the forecast said it would be sunny.
Had to leave urgently so drove away with 30 % SoT and ended up at a SuC with 1% SoT, the temperature was around 33F so very cold, the car only heated the battery for approximately 15 minutes right before i arrived so expected it to not be able to do very fast charging.
Plugged it in and was hit with 33Kw
Had to get something to eat so i thought i would just leave it, the app said it was heating the battery and charging would surely heat up the batteries as well, so i fully expected it to ramp up the power when the battery got warmer.
After 30 minutes it had only gone to 35KW so i decided to plan to go to the next SuC, where i would arrive with 12% SoT, the trip was only 40 miles. Drove off and was p*ssed to find the car was not immediately heating the battery like i thought it would.
After driving 25 miles it finally started heating, but 2 miles before the charger it turned off the heating even though the SoT was still at 10% so plenty of power to heat the batteries.
Plugged the car in, fully expecting it to be limited, but to my surprise it flew past 200 KW and did a normal charge and i was on my way. (So in reality the batteries had probably been well heated at the first charger, hence why it only did a bit of "maintenance heating").
Yesterday i had to do a 300 miles roundtrip so at some point i stopped to charge and even though it had been heating the batteries for 30 minutes and the temperature was more like 40F it again started charging at 33 KW.
I unplugged after 1 minute, reversed to the stall just behind and plugged in and again it just took off above 200 KW...
So...Now i think maybe there is a problem, either with those chargers or more likely my car.
Has anyone else experienced this and if so....Did you resolve it, and what was the problem ?
