Also, I thought either the manual states or Elon has said that the expected degradation rate is 1% per 10000 miles. So seeing that he is 7% at 75,000 miles is spot on to what Tesla said the degradation would be.
source?
This language is imprecise. Can you tighten it up?I hadn't seen that anywhere before, but with this long range example plus the Roadster long term battery study I will now be answering the question of "how long is the battery good for?" with "a couple of decades if you drive the typical 12,000 miles a year."
If you haven't seen the video in this thread already (it's a long 75 minute watch, but good if you're curious about how Li-Ion batteries are studied and their lifetimes projected), watch it:
Why do Li-ion Batteries die? And how to improve the situation?
I wouldn't call that "good" myself. In truth the definition must be flexible, since it will have different meanings for different people. Those pushing the pack capacity when new may not feel the pack is "good" after a 20 mile range loss, others might be fine with 100 miles of range loss.
Elaborating: Isn't the battery technically "good" as long as it supports at least 1 (rated) mile of charge?
Correct if I'm wrong, but doesn't the video also shows that the cycling done in labs doesn't accurately predict real world lifespan due to the effects of storing cells at higher/lower socs and higher temperatures? Unless those NCAs were cycled under the realistic conditions described around the 5:50 mark of Dahn's video, which I don't think is viable since it would take ~7 years of real world testin to predict 7 years of real world use, or Panasonic used his high accuracy/prescision calorimetry to determine lifespan, which I'm not aware of any manufacturer doing, and something they probably didn't do in that pdf since they just reference the usual charge/discharge cycling, then we can't assume their batteries will last ~500k miles and still have 70% capacity.NCA chemistry tested beyond 2500 cycles shows no abrupt capacity loss and 70% capacity retention, which would be over 500,000 miles.
Page 20: http://www.embedded-world.eu/fileadmin/user_upload/pdf/batterie2011/Sonnemann_Panasonic.pdf
The video I linked shows that Professor Dahn's predictive methodology does in fact provide a way to reliably predict cell life cycle.
