Some other things I wrote in the tesla blog:
# Anatoly Moskalev wrote on June 10th, 2007 at 9:25 am
## To NiMH EV:
## Tesla Motors seems make their choices to keep 200+ range versus to have outrageous 1/4 mile timing and other racing capabilities.
Yes, the more I learn about the inner workings of the Roadster, the more I see how they crafted a "balanced" set of parameters to meet a number of design goals. To me these goals all make sense, and I would NOT want to suggest changing anything. Now, Tesla started with other designs (e.g.; ACP TZero) as a basis, so they had a good starting point, and many of the differences appear to be "incremental improvements", although the ACP people seem brilliant so improving their designs takes some serious skill!
## But if someone set several IGBT in parallel,
## add small inductances for temporal energy buffering and allow IGBT swith one after another with some phase shift it
## would reduce IGBT swithicng limit impact considerably.
Thanks for that information. I know Tesla added more IGBTs to improve their torque curve on their PEM, but I didn't have any idea how adding more would make it possible. Your description gives me an idea of how they may be doing it.
IGBT 101:
http://www.powerdesigners.com/InfoWeb/design_center/articles/IGBTs/igbts.shtm
## I believe hard IGBT switching related limit comes at higher frequency than needed for EV
## so it is hardly a show stopper limitation to get much higher eMotor power than what exist in Tesla roadster.
Really? Well maybe I am wrong that IGBT limits cause them to have to drop torque starting at 6000RPMs, but some AC motor controller design articles I read suggested that IGBT switching limits would cause a torque dropoff just like what I see for the Roadster.
## Choice of voltage versus current for eMotor and ESS most likely was driven by trade off to avoid too much
## electrical isolation complexity on one side and too heavy wiring on another.
Yes, I considered that. Yet another area where it is an "art" to balance all the constraints and still meet the design goals.
## Just the safety issues for mass market will be severely difficult but for some racing it could be done.
Yes, I think they are already pushing the limit of what they would like to do safety wise. There would be safety benefits and easier design to use a lower voltage, but they need some of the benefits of going with higher voltages. If you look at the history of EVs, the voltages keep going up. Year 2000 EVs (like EV1, Rav4EV, EV1) used ~300V systems. Now Tesla is going closer to 400V. Many older home brew EVs use much lower voltages like 96V. Toyota hybrids tend to use a lower voltage battery pack, but then use a circuit to boost the voltage right before it goes into the eMotor.
Some comparisons:
Year Bat Motor kW Model
1997 288 288 30 Prius gen1
2000 273 273 33 Prius gen2
2003 202 500 50 Prius gen3
2005 288 650 123 Highlander Hybrid AWD
2006 288 650 147 Lexus GS450h
2006 245 650 105 Camry Hybrid
2007 400 400 185 Tesla Roadster
Notice how Toyota has been using a more and more aggressive "boost converter" to raise the battery voltage before they run the eMotor. So does that mean that Toyota uses IGBTs rated for use at 650volts in their latest hybrids?
Given that Toyota is limited in NiMH capacity by Cobasys, it is amazing the power increases they are getting on their eMotors even though they can't increase the traction pack size. Their P/E (Power-to-Energy) ratio keeps going up. The GS450h has only a 2kWh pack, yet produces 147kW from the eMotor. (can they really get ~70C power from their batteries?!)
http://www.lexus.com/pdf/models/GSh_driving_performance_guide.pdf
http://www.greencarcongress.com/2007/02/the_lexus_gs_45.html
http://www1.eere.energy.gov/vehiclesandfuels/pdfs/program/phev_rd_plan_02-28-07.pdf
http://www.ipieca.org/activities/climate_change/downloads/workshops/27sept_06/Session_4/Wimmer.pdf
http://www.ricardo.com/download/pdf/R119361S.pdf
It appears that Toyota is using a strategy of higher voltage, lower RPMs as compared to Tesla.
The Toyota hybrids have eMotor horspower relatively flat from around 1200 RPMS through to a modest redline.
(no 13500 RPMs like Tesla)
Their flat torque curve (as HPs rise) goes from 0 up to a modest / low RPM.
(no 0-6000RPM flat torque like Telsa)
Peaks torque/power RPMs:
MaxTorqueRPMs : Model
0-0400 RPM Prius Gen 1
0-1200 RPM Prius Gen 2
0-1500 RPM Highlander & Camry
I wonder how things would have worked out if Tesla had picked different targets:
600volts
Torque peak up to 4800RPMs.
375hp @ 5000 RPMs.
9000 RPM redline
Would they have been able to get the same performance and range if they configured the ESS, PEM and eMotor to do that? From a marketing standpoint, higher torque and HP numbers would have been attractive.
Maybe they couldn't do that because of battery power characteristics, so they had to meet HP numbers with wide power band rather than higher HP.
I think Telsa is really "pushing the envelope" with motor RPMs and high torque peak for an EV.
I wonder why they chose such high revs rather than higher voltage...
# Roy wrote on June 10th, 2007 at 7:43 pm
## As many have noted the torque remains constant from 0 to some rpm and then falls linearly.
## At the same inflection point the horsepower stops going up.
## The horsepower does not drop at this point, it is just that it has reached its maximum design power output.
## If excess voltage were to be applied, the motor would burn up.
OK, so I can see them using the "flat torque" algorithm from 0-6000 RPMs then they get to "target HP" and switch to "flat horsepower" algorithm. Yet eMotor HP/Torque graph shows horsepower falling past about 8000 RPMs. Is this intentional due to eMotor heat too? Can eMotor only produce ~250hp for a short time then needs to drop off?
So what happens if you did something awful like pull a heavy trailer with the Roadster such that you were using all of your 200ft-lbs of torque and you got up to ~7000 RPMs and torque started to drop off so you couldn't accelerate any faster. Now you are stuck at max HP for an extended period of time. Would the batteries or eMotor die at that point because you failed to accelerate into the HP dropoff zone above 8000 RPMs? What about someone with a load of gold bricks in the trunk trying to drive up a very steep hill at sustained 8000 RPMs? I wonder if the PEM will limit voltage / horsepower intentionally even if you stay at 8000 RPMs. Perhaps the eMotor graph published by Tesla is only if you accelerate through the range without staying at max horsepower for too long?
