I don't think it is economic. A PowerWall will cost over C$4000 and that is before an inverter an installation. And how long can you run on 7kWh? A generator makes much more sense. The math might start to work if the peak to off-peak delta increases from the current $0.09 as you could also use the PowerWall to arb this pricing differential. At current prices you would save about $1/day by charging the battery at night and discharging during the day to offset your peak load - assuming that the local utility let's you do this - does Tor Hydro? But then you run the risk of draining your battery when you would want it fully charged.
